665 Tiller gearbox oil
   / 665 Tiller gearbox oil #1
jeffster
SW Washington
JD 3520 w/ 300CX
Ok, so I took the plunge and bought a 665 for my 3520 and I really like it. However, I noticed after doing the test run that the gearbox oil is milky. I contacted the dealer who said they fill it when it comes in but that it likely had water sitting in the bottom. So, I'll change that out myself since it is an hour's drive back to the dealer. Not too big a deal to change it (and I am **** about checking fluids so I caught it). My question is, any concerns that I ran it for 30 minutes this way? It of course wasn't milky when I checked it before use, otherwise I wouldn't have used it that way. Thoughts?
   / 665 Tiller gearbox oil #2
It should be ok, I'd run it alittle more then change the oil again, that should get what little, if any water was still in the gear box out.
   / 665 Tiller gearbox oil #3
It may take a bit to clear it all out. I had a similar experience with the top gearbox on a Tarter I picked up from TSC. I still saw some evidence of contamination after 3 flushes, with no load operation in between each ...
Do let it settle a bit before checking after use, I think churned in air could possibly look similar.
Nick
Thanks guys, appreciate the thoughts. It poured today so I haven't been back out but I'll go take another look tomorrow and see if it still looks the same. Thanks again.
   / 665 Tiller gearbox oil #5
I think a lot of it has to do with cast-iron gear box and the way it only sits with a little gear oil in the bottom. My is always that way in the spring, it seems heating and cooling over the winter lets plenty of condensation in and you get the emulsified milky gear oil. I usually just flush it a couple of time with some keroscene and then add GL-5 in the spring.
If you let it go too long you will get some pitting on the shafts, but if you keep up on it I wouldn't worry about it.
Dan
Ok, so I went and changed the oil and this is what it looked like. Pretty ugly...
-Jeff
   / 665 Tiller gearbox oil #7
Dan
Yep... that's been my experience too. Haven't tried the Kerosene route, though. Better refined than diesel; which is what I've got lot's of.
I use one of those brass hand-pumps that are found in the boat supply catalogs to suck out the remaining diesel-gunk mixture before putting in new gear oil.
AKfish
   / 665 Tiller gearbox oil #8
Yep, that's pretty milky!
Nick
   / 665 Tiller gearbox oil #9
AKfish
In between flushes with 90 weight, I used diesel with some gas line antifreeze (methyl alcohol). Don't know it it helped much, but was willing to give it a try. Final fill was 85w140. I agree about the suction gun. Much less messy than the side bottom drain on my top box (& didn't leave anything left to drain when the drain plug was removed).
Nick
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
