houstonscott
Elite Member
- Joined
- Dec 19, 2010
- Messages
- 3,674
- Location
- Oglesby, Texas
- Tractor
- Kubota L3800, Kubota GR2120, Kubota RTV1100, Kubota 5100sc
I understand the principal. I'm just saying that for me, it wasn't worth the work having to move the frame around when I had the same amount of luck just pulling the tree over. I'm removing White Oak, Live Oak and Chinese Tallow trees. It surprised me, the tree that was most difficult turned out to be the trash tree, the Tallow. A few of the Live Oaks broke off instead of coming out with the root ball. However, most of the Tallows are breaking off because even though they have a soft wood, they have MAJOR tap roots. The tap roots on the ones I've successfully removed with roots and all are as big around as the actual trunk of the tree and go down really deep. I plan on renting a BH to dig out the stumps of the trees that are breaking off.
Similar experience. Most trees pull or push over with the root ball coming up. Saplings can be chained at ground level & pulled out, but the bigger the tree the higher up we (must) put the chain. Above about 7" or 8" in diameter, my tractor usually just can't get 'em, either by pulling or pushing. Occasionally one here & there breaks off near the ground, which is a pain. I've been digging the dirt from around those & cutting them off as low as possible with a chainsaw. I've actually pulled so many saplings & other trees since last June that I've now broken four 5/16" chain links ... from the back-&-forth bending some links get when you hook the hook on it one way one time & the opposite way the next time: Just a slight bend back-&-forth a bunch of times, & they finally snap.
I'd like to try an A-frame, to pull up, but not sure it's worth the extra.
It would be fairly simple to make something like that but unfortunately, that system will not work well on a tractor but only on a skidsteer. You must maintain sideway force as you move back and forth to saw the tree and I think that could only be done effectively with a skidsteer.
Here's my version of the tree gitter (see photos). To use you lower it, back up the tractor so the tree goes into the "V". Keep backing up and start to raise the 3pt and the tree will come out of the ground roots and all. Sometimes it sticks in the tree gitter, and sometimes it falls out on its own. Works great though, and was built for peanuts. In case the phot isnt good enough, the "V" shape is sharp inside, on the bottom edges. And, for clarity, both edges are fixed, nothing moves. The flat metal is !/4". The space between them is 3 or so inches, and tapers to virtually zero.
That thing just saws off the tree at ground level. Many trash trees will simply regrow unless you mow frequently. I prefer the type of device that pulls the whole root/stump out and that type of device is much less expensive (or easier to build).
OK, now I have another question for you guys. I have lots of what we here call choke vines. ...
I have similar clogs. I've been chaining & dragging many of them down. On others I've been using my Stihl pole saw to cut them off as high as possible, usually ~15' above ground, & leave 'em. I know that's not what you want to do, but I'm not sure there's a good, low labor way to get them down.
I also cut them off and leave them now. I used to grab them with the grapple and back up trying to pull them out of the tree but almost got nailed a couple of times when the vines ripped branches loose that then shot towards the tractor like and arrow shot from a bow. Those vines are strong and well attached even if they look like they are just draped over loosely. I just cut them and grapple out the roots now.
Yeah, I was worried about pulling down branches too while trying to pull the vines down with the tractor. I know from cutting up the trees I've pulled down with the vines growing on them that they hold tight. I've had to use looping shears and the chain saw to cut the vines as well as the tree as I cut up the tree for removal to the burn pile. Looks like I'll have to cut the vines at the base then use a pole saw to remove the vines as much as I can then let nature take it's course on rotting the rest. Oh well, I need the exercise anyway.
My idea is to wrap a chain around as many of the vines as possible and try to pull down what I can with the tractor from far away then do the manual thing on the rest. I was just hoping someone could give me an idea that would save some work. Like I said, there are areas that are too thick to even work your way through trying to walk. I'll just have to start on the outside and work inward.
