PT425 Subaru Starter Blow Out @ 29 Hours
   / PT425 Subaru Starter Blow Out @ 29 Hours #1
FAZTRAC
Flatistan and Tenn. (part time)
PT 425 & john deere hydrostatic, DR Brushcutter 17 HP!!!!
New PT 425 with Subaru EH72. Hitachi Starter solenoid decides not to disengage at 29 hours. How unfortunate. I shut the motor off and the starter motor is still cranking until I could get a wrench and get a terminal off battery. Bench tested and did the same thing, once powered... would not disengage. Used all the smoke and mirrors I had to get the starter out without pulling the engine. Ended of drilling a hole through the side of the tractor in line with the upper, starter bolt head to get at it with a socket and long extension.The bolt head was buried behind electrical wires under tension. There would be no getting a socket on the bolt head without carefully watching and moving wires out of the way with a long screwdriver. Without hole you are working with mirrors and feel.XXXXXX!!!
Subaru wants to send me only a solenoid. It is true that the solenoid is the culprit, but how long was that starter motor running while I was working the tractor(I wear ear muffs)? I will never trust that starter to have a normal life span after this. We are in the middle of a massive project and we tried to get Subaru/Dealer to send solenoid Fed Ex overnight and told local Subaru dealer we would pay the overnight freight. No show. What a surprise.
Looked up Subaru/Robin parts on the Internet. Good luck getting parts for an EH72. I think I would stand a better chance of getting on the space shuttle. I see no parts look up for Subaru on the Robin web site. The dealer is new to Subaru.... says "their parts look up is very frustrating".
Does anybody else have a parts source? Thanks.
   / PT425 Subaru Starter Blow Out @ 29 Hours #2
The Robin website is
Subaru Robin
There are parts manuals there for several EH72 engines.
For example, the following link, page 26 shows a complete starter with part number and all of the internal parts exploded by number. Not sure if this is your engine, though.
http://www.robinamerica.com/media/manuals/129248179497999320.pdf
Moss
Thanks so much. I guess I was too aggravated to find anything.
Hopefully at least the solenoid will appear today. I fear I have become
too dependent on this wonderful little machine. It is amazing what it will do
FAZ
   / PT425 Subaru Starter Blow Out @ 29 Hours #5
Moss
FAZ
Yeah. I could sense the aggravation and urgency in your post. I, too, really have come to depend on out little green beast. So much so, that I have stopped using it for simple things just so I can get some physical exercise. I think I've gained 20 pounds just from owning it! :laughing:
   / PT425 Subaru Starter Blow Out @ 29 Hours #6
Try Continental Engines at 800-922-5632. I have had good results with them. Very knowledgeable.
   / PT425 Subaru Starter Blow Out @ 29 Hours #7
I will second jacks small engines.
Here is the EH72 starter motor assembly...
Jacks Small Engines Search
For $299, you might want to rethunk buying the whole assembly.
   / PT425 Subaru Starter Blow Out @ 29 Hours #8
You have found the main problem with the PT. You get fat. I now use a wheelbarrow for my firewood just to get some exercise.
   / PT425 Subaru Starter Blow Out @ 29 Hours #9
Using the PT to get the mail is a bit much as the mail box is only 100 yds.
   / PT425 Subaru Starter Blow Out @ 29 Hours #10
FAZ,
If you get desperate, I still have the OEM standard duty starter laying around. I doubt that it has been used for 50 starts. JackRobin sent me the HD version at no charge to try to fix my cold starting problems. I think it will fit in a USPS medium flat rate box.
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2011 BOMAG BW211 D-40 SMOOTH DRUM ROLLER (A51246)
2011 BOMAG BW211...
(APPROX 20) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 20) 2" X...
LOAD OUT INFORMATION LOT IDENTIFIER 4 (A53084)
LOAD OUT...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
