new slab seal or not
   / new slab seal or not #1
toyocruiser
Central Alabama
I just finished pouring a 60'X60' slab.
It was power troweled to a very smooth finish.
Will build a 40'X60' shop with a 20'X60' lean to.
Am trying to decide whether to seal all, part, or none of it.
The purpose of the slab is to be a shop, but the wife and I will live in 1/2 of it while we save enough to pay for a house to be built. Timeframe 2-3 years.
Appreciate any info and recomendations.
toyocruiser
   / new slab seal or not #2
I'd at least seal the part you are going to live in unless you plan on putting down some type of floor covering. Concrete is a porous material and you might get dampness if not sealed. Be sure it is cured enough before you seal it however. Actually concrete continues to cure for a VERY long time.
   / new slab seal or not #3
If you don't seal it, you will have a lot of cement dust to contend with. But if you seal it, it might be kind of slippery if it gets wet.
   / new slab seal or not #5
NOoooooooo!!! You don't need to "seal " it, you need to put a coating on it. The new Polyureas are awesome for durability. Car tires won't damage it and it will hold up to solvents.
Yeah it will cost, but will last a lifetime or more. If you are planning to move, then maybe you don't want to, but otherwise, you can't go wrong. Here is a local place, there must be similar near you, and don't take the "epoxy is just as good... story":
Polyurea Floor Coatings, Polyaspartic Finishing Systems, Garage Floors
   / new slab seal or not #7
toyocruiser
If you ever intend to put a flooring layment on top of the concrete that will not bond to sealer, such as an epoxy cover, a mud mat for tile, or glue for engineered wood, then do not seal it unless you want to acid-etch the sealer off or scarify it off. Most adhesive and / or bonding type installs will not bond to a sealer (or in most cases).
A surface sealer does very little for moisture or dust control. It makes the floor shiny for a while but then does little of anything further.
   / new slab seal or not #8
I have never sealed a concrete floor and have never had any problem.
The vapor barrier is the plastic sheet you put over the gravel before you poured.
A layer of goop on top of the concrete will only make it slippery when wet.
   / new slab seal or not #9
Use a cure and seal. It helps your expensive 'crete cure properly and makes for a nice sweeping. You said thet you troweled it smooth so that will be as slippery when wet. (as the sealer)
   / new slab seal or not #10
Tomahawk 42" Skid Steer Pallet Fork Attachment, Asset# 72 (A59076)
Tomahawk 42" Skid...
Scrap Water Tank, Asset# 61 (HAS HOLES) (A59076)
Scrap Water Tank...
72in Forklift Safety Basket (A56857)
72in Forklift...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
Hays LT-1 Tender (A56435)
Hays LT-1 Tender...
