carpetfarmer
- Joined
- Apr 16, 2011
- Messages
- 5
- Tractor
- Ford 2N
I'm posting this for a friend who's having a real rough go of things here lately and needs to sell his tractor.
It's a Yanmar YM2000. The rear main seal is out of it and needs replaced but other than that it runs good, no lights. It had new bushings in the steering about two years ago and since then it steers very hard even when moving. It has a four speed transmission with high and low ranges and a two stage clutch (halfway down to shift gears without stopping PTO, all the way down to shift gears and stop PTO). It's got a three speed 1 3/8" PTO (I don't have the manual, so I don't know the PTO speeds, exact hp or year). There is also an PTO overrun clutch with quick coupler which can be moved to other implements very easily.
Comes equipped with a Koyker 110 Loader and 4' bucket that is in great shape! There is also a 55" ISEKI RA1360 3 pt. mounted rototiller, Leinbach post hole auger, 5' box blade with ripper teeth and a Razor 5' rough cut rotary mower. The counter weight will not be sold. He used the tiller one time and said the tractor would handle it but a bigger tractor would really be better, this tractor didn't really have enough mass and just got thrown all around, also just a little underpowered (however, it was hard ground that had not been worked before so that makes a difference).
I have operated this tractor prior to steering problem and its a great little tractor. I know he has used it for a lot of things and has done a lot of work with it.
I'm interested in knowing the price of the whole lot as well as possibly individual prices. Everything will be sold together except maybe the mower and box blade, as I am interested in purchasing those for use on my 2N. If I can swing it, I would also really like to purchase the tractor from him as well.
Thank you in advance, your help is greatly appreciated.
