Can you come help me mow
   / Can you come help me mow #1
chucko
Polk Co , Fl
bx1800
I get a call for Sis and BIL who took on a mowing job that was too much for their mower and wanted me to come help with my bota. This is what I found when I got there.
   / Can you come help me mow #2
I wouldn't even want to do that with my BX without the rotary cutter. It will do it, but I sure hate to.
   / Can you come help me mow #3
Looks like a lot of work for the mower operator, a lot of head turning, paying attention to where you are at, avoiding all those obsticles, type of job....
   / Can you come help me mow #4
I agree, not a job for a mower, but more for a rotary cutter to knock it down first then maybe and that is just MAYBE run back over it with a mower. Even then the surplus growth will tax the belts on a mower, although some of the better ones will go thru it with no problems. I would probably attempt it with my Steiner 525 as it has plenty of power, good belt setup, and hydrostatic so I could creep into some of the thicker bunches without overloading the mowing deck. Still could be a problem with hidden items, that a rotary cutter would take in stride (and throw across the yard). Layering the cuts, first high and then lower when you can see might be a smart move, but requires double cutting.
If you have already done this, and didn't tear up anything, good job!!!
David from jax
I gut with the deck set to "top" and it was really still too much. I will not be doing that again
   / Can you come help me mow #6
I wouldn't either. It amazes me what these BX's will cut, but that sure is pushing the envelope.
   / Can you come help me mow #7
Agreed - rotary cutter...or as I called it growing up on the farm in KY... a bush hog. I have mowed many times through stuff like that with our old bush hog but not a finish mower. That would be slow going.
   / Can you come help me mow #8
IMO that needs to be bush hogged one week, flail mown the next week or two, & then finished mown in another week or two.
   / Can you come help me mow #9
You can bush hog/rotary cut that just fine. Just use the right tool at the right speed for the right job.
   / Can you come help me mow #10
Should be done by now then. With the mmm you just need to go over the tall stuff twice.
larry
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
