4300 bucket curl 'dead spot'
   / 4300 bucket curl 'dead spot' #11
i would say it is probably the regen circuit. when i put on my front blade i would get the same dead spot when i would angle the blade. changed the regen lever and the problem was cured..........bud
i will try that 1st before i go changing hoses around. i actually can't remember if i have it in regen mode or not, have to check the book to see what the symbols mean...can never remember.
   / 4300 bucket curl 'dead spot' #13
Did anyone read my reply:confused2:
   / 4300 bucket curl 'dead spot' #14
That is becasue the blade has two SA (single acting) cylinders, when in "regen" both lines are pressurized causing the blade to "stall".
of course i read it...just didn't understand why under some weight, it works fine but over a certain weight, it does not. also wasn't sure how part #43 had anything to do w/ 'load check'...i didn't want to bother you with stupid questions until i tried some other simple things 1st.
   / 4300 bucket curl 'dead spot' #16
Part number 46...:eek: Sorry about that.
ok, that's what i thought you must have meant, but wasn't sure. is it possible for this check valve to work fine w/ 200lbs on the frame but get 'forced through' w/ 300+ lbs?
not sure i am asking that right, hope it makes sense.
   / 4300 bucket curl 'dead spot' #18
Yes-it make perfect sense, and yes-it's very possible, more weight=more pressure it need to hold.
Here is a recent thread-nothing definite was determined though: http://www.tractorbynet.com/forums/...g/187788-jd-430-loader-hydraulic-problem.html
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
UNUSED TELESCOPIC LADDER - 2.5M+2.5M (A54757)
UNUSED TELESCOPIC...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
