Can you come help me mow
   / Can you come help me mow #11
I bought Kubota new off dealers lot. Drove it home, about 5 miles, 30 minutes, then, with 2 hours on the tractor, broke it in with this. Not what I wanted to do, but had to do. 17.5 acres worth of this stuff. Philip.
   / Can you come help me mow #12
You used the mower we pretty much suggested for the o/p project (or should I say the project he got suckered into, lol?) The tractor is just the power supply to turn the correct implement needed to do a job.
David from jax
   / Can you come help me mow #13
Whatever implement you use, try not to knock over those bee hives. . .
   / Can you come help me mow #14
Did you mow it or decide against it? It's definitely a job for a bush hog type mower, not your mmm deck. But if you absolutely, positively had to mow it, you do have a box blade and maybe a FEL on the BX, right? You could use them prior to mowing to find and level or remove the worst of the protruding obstacles that would beat up your deck. Not the best solution, but that might save you some grief. Then mow it, taking slow, small passes so the deck can process what you drive over and you can see what is being mowed a little better.
Be careful of that darn plastic fan, and mind the beehives as well ! Good luck!
   / Can you come help me mow #15
I get a call for something like that on occasion, Stihl KM90R with a straight shaft string trimmer attachment, and my helper gets the FS55...it ain't that bad of a job, really...just keep telling yourself that and you'll be fine.:cool:
   / Can you come help me mow #16
My BX and 48 in rotary would have kocked that right out.
   / Can you come help me mow #17
it actually does not look that bad. compared to what i have ran the allis chalmers CA with belly finish mower.
take 1/3 to 1/2 passes. mower deck set as high as possible with the main discharge side of deck furthest away from cutting.
i do not like stating it, but make sure you can see the pulleys or spindles/shafts for each pulley easily when on the mower. tall weeds can quickly clog a mower deck up. and if you can keep an eye on the shaft it is much easier to unclog vs waiting for you to smell the belt burning or nothing is getting cut. ((center pully)) atleast for me. is were the belt wraps around it a couple times, so that blade / pulley / shaft normally ever gets clogged up.
cut everything you can. with above, then hopefully by the time your down. the rest will by dry enough to come back with a slightly lower deck if not all the way lower.
if it gets to dark, or to wet, i try not to leave things go longer than a day after the inital cut. or less the weeds and grass end up matting, making next time mowing to cut it down harder.
long handle straight screw driver, a utility knife, some paper towels and jug of water. paper towels and water is to wash off. you can get a bunch of bugs and slime on ya. when ya underneath the deck pulling the clogs out.
The puc is a little misleading the part that were "grass" was thick thick. When mowed at top the cut grass would lay half way to your knees. I used at box blace to "rake" the cut crass into piles that looked like busted round bails.
Also thouse were not bee heives but corner colums at the old gate. It is conc. block(s)
John Deere 333E (A47477)
John Deere 333E...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
300# CLUTCH JACK (A53843)
300# CLUTCH JACK...
PRINTER (A53843)
PRINTER (A53843)
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
TEREX RT665 MOBILE CABLE CRANE (A51406)
TEREX RT665 MOBILE...
