Question regarding top link on BX@#
   / Question regarding top link on BX@# #1
Concordriver
Member
Eastern Massachusetts
Kubota BX24
   / Question regarding top link on BX@# #2
By "ring" do you mean the little loop welded to the side of the toplink barrel?
You can see it very clearly here:
note that the area of interest on my BX1860 seems to be different compared to the BX24/25, presumably because of the BH attachment hardware.
Regards,
Wrooster
Yes. That is the loop I am referring to. On the BX24 it is closer to the tractor end of the top link. Do you know what that loop is for? In the photo I attached with my first post, there was a brass clevis pin inserted in that tractor's loop.
   / Question regarding top link on BX@# #4
That ring, if I follow what you're asking, is for putting a lever through like a flat bladed screwdriver so you can adjust the length of the top link when there's weight on it.
   / Question regarding top link on BX@# #6
On mine a 10" cresent wrench will slide in there and the jaws are just big enough to fit the lock nut on it!:thumbsup:
   / Question regarding top link on BX@# #7
I also hook my safety chains to it if it is the one I am thinking about.
   / Question regarding top link on BX@# #8
Note that the top link is reversible, if you take it off the tractor and put it on the other way 'round there is no difference. I agree with the poster above, the ring is useful for adjusting the overall length while the toplink is under load. Moreover, the little ring provides a useful place to attach the PTO shaft guard chains to. These chains prevent the shaft guard from rotating with the internal PTO shaft.
Regards,
Wrooster
SKID MOUNTED WATER PUMP (A55745)
SKID MOUNTED WATER...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A55788)
2008 Ford F-250...
(10) 12' Wood Poles (A53316)
(10) 12' Wood...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2016 Morbark Chipper (A55787)
2016 Morbark...
