new tractor with oxidation / pitting
   / new tractor with oxidation / pitting #1
tractordog
Southern New Hampshire
T1520
Hi,
got my new tractor, and I have some heavy pitting on the hydraulic lines. I noticed that the older tractors it is a smooth oxidation not pitting. I think where it was parked must have got a good shot of salt.
Do you think this will cause problems in the future?
   / new tractor with oxidation / pitting #2
Hard to say long term but I would think some metal polish would take it off. "Eagle One Never Dull Wadding Polish" that I have I think would work. I would certainly try to remove it before it gets worse.
Good luck
tom
   / new tractor with oxidation / pitting #3
Hi,
If it's brand new, I wouldn't take delivery of it!
Is that brand new or is it new to you? Must be the latter. I'd pressre wash it really good. It must have been operating somewhere in a marine environment, in a salt mine, or possibly with a a highway or road department to have that much pitting.
Of course the pits will affect the fatigue life of the tube but whether that's a five year problem or a 20 year problem is anyone's guess.
   / new tractor with oxidation / pitting #4
I would wash it very well and remove those clamps to wash underneath them as well. Take some 000 steel wool to it I would then clear coat them with a couple coats of spray paint. I don't think you will have any problems with it down the road if you treat them properly now. I think at this point it is more cosmetic than anything.
My local NH dealer has a brand new tractor that has sat out now for approx 1 1/2-2 years now and it is rusting all over and the black dashboard plastic is faded that dull gray. Going to have to sell it cheap now to get rid of it.
   / new tractor with oxidation / pitting #5
Mine sat right next to a main road, all winter. It had some of that kind of corrosion.
I sprayed it all with a light weight oil, and it has been fine for the last 6 years. Steel wool will remove it, but it will also remove a lot of the coating that is protecting the lines.
Thanks for the replies,
The dealer is coming out to replace the lines. I did not even think there might be coating on them. Does anyone know what the lines are made of. I know with aluminum you only want to use the green scotch pads.
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2017 Nissan Altima Sedan (A51694)
2017 Nissan Altima...
