New woodsplitter
   / New woodsplitter #22
Speaking of splitters-- I've never used a vertical splitter; Johndeere3720, what are the advantages/disadvantages? Do you raise up the rail once in position? (Does it lower for towing/storage?) How does that work?
I'm still at the point where I have to borrow one from my brother, but I always think about that line in the song (Blood, Sweat & Tears) "God bless the child that's got his own..."
Really don't like to be in a position where I have to borrow stuff. I think it's only a matter of time before I convince myself I need a splitter...:laughing:
Mine I just pull a spring loaded pin and it easily tilts backwards for vertical splitting. When making it horizontal, you just tilt it back, mine i have to hold a hydraulic hose out of the way but the pin just snaps in and your ready for transport. :thumbsup:
   / New woodsplitter #24
One thing that's not mentioned, I don't think, above, is that little 2 way PowerHorse unit is not road towable. Might not matter, but to some it might. The big advantage that I see to that unit, aside from price and the 2 way thing, is that it appears from the picture to be much shorter than most regular units which could help in storage.
   / New woodsplitter #25
I got a Troy Built 27 ton log splitter and it has just amazed me. i split about 8 cord last fall, probably just about double that is in the plans for this year. I have split wood that was near impossible to do with a splitting maul and it just splits those rounds like a hot knife through butter. Mine has the Honda motor, very very good motor. It is so quiet, no ear protection is needed while operating it and the motor has never skipped a beat.
I purchased the same one and I don't have any complaints at all. :thumbsup: I have had it about a year and it starts every time. Mine is a 5 hp Honda motor also and I like the fact I can tip up the anvil vertical or horizontal. If I had to improve on anything, it would to decrease the cycle time and a 4 way anvil. Do they even make a 4 way anvil for this or are most home made?
   / New woodsplitter #26
I have a Huskee 22 ton from TSC and it works great. I split more than the average guy I guess, and it has worked like new for several years now. The briggs engine has been perfect. I let it run dry before storing for more than a week and it starts right up every time.
Be sure to check those Honda engines before buying. They import junk from China just like some of the others, so not all of their engines are great. They made nice engines for years, and now they are cashing in on their name.
   / New woodsplitter #27
That's the one I have too. It has two stage hydraulic pump and slows itself when in tough stuff. The great thing about vertical operating is you don't have to pick any log up completely, just tip one end up. Much easier on the back.
   / New woodsplitter #28
I recently did a side-by-side comparison (in the TSC parking lot) between the Huskee 22t and their next larger 28t.
Both have the same size wedge and foot. (they appear to be identical)
The 28t has a larger diameter cylinder.
Both have an 11gpm pump.
Cycle time for the 22t was faster.
The 22t has the B&S 190cc engine and the 28t has the Honda GC 190cc engine.
The 22t has the engine on the operators side, 28t has it on the other side.
The B&S on the 22t was quiter.
The B&S has an adjustable throttle, the Honda is on/off only.
When I'm ready to buy I will be looking at the 22t.
Also, regarding the Honda engine, there is a big difference between the GC and the GX models.
   / New woodsplitter #30
Yeah, 955er, I would assume those flywheel jobs are for people splitting huge amounts of firewood, mostly of manageable size, in commercial type operations. Without being able to use them vertically, they're not much good for the very large logs we homeowners have to split horizontally from time to time. They are really cool machines, but as you mention, the price puts them in the class of people who are splitting 20 or more cords (at least) per year, not for the homeowner who is splitting four or five cords for sure. Fun to watch though.
17201 (A55852)
17201 (A55852)
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
202477 (A54757)
202477 (A54757)
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
2005 BRIDGEVILLE 53' DRY VAN TRAILER (A54756)
2005 BRIDGEVILLE...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
