Bit the bullet on a 4720
   / Bit the bullet on a 4720 #1
Tritonman
Gold Member
Well I bit the bullet on a new 4720 today. Pretty jacked up to get it home and load up the accessories. Do any of you guys mount a tool box onto the tractor or loader? I have thirty acres of test plots that I do alot of work in including planting, spraying, etc and am pretty excited to give it a whirl.
If anyone is interested I have a set of R1 ag tires for sale including rims off of a 3320!
   / Bit the bullet on a 4720 #2
how much and where are they??
   / Bit the bullet on a 4720 #3
Congratulations!! Nothing finer than a new, Green machine on a sunny, Spring day!
Lookin' forward to seein' your pictures!
AKfish
The tires are in North Dakota and are in nearly pefect shape. 900 dollars plus shipping. Which is probably around 300 to the east coast or gulf coast
Anything I am missing, that you guys would add. I ordered a 4720 with the cx loader, R1 tires, Third hydraulic, adjustable draft links, topntilt (fourth and fifth hydraulics) deluxe hood guard, horn, radio, skid steer quick attach, heavy duty bucket, economy pto automotive cruise control, rear window wiper.
Do any of you guys have the front fenders or the rear fender extensions. I run a sprayer and am kicking around the front fenders for that reason.
   / Bit the bullet on a 4720 #6
Congratulations on your new tractor sounds like it is well equipped too.
How about six rear wheel weights, I put these on my 4520 and really helps with traction.
I also added the rear work lights.
   / Bit the bullet on a 4720 #7
I don't know if its standard with the cab, but a lot of guys rave about the deluxe air suspension seat.
   / Bit the bullet on a 4720 #8
Fenders are nice when going from mud to hard surfaces where they really fling it off. Rear extentions would depend on how far you set the rear wheels out if needed or not.
   / Bit the bullet on a 4720 #9
JD has a metal tool box that mounts on the front grill gaurd for the 4000 series. It is not huge but can hold the essentials. The FEL will just miss it as it raises and lower. Simple to mount with 2 bolts. Price was not too bad if I remember correctly. It is probably the best place to mount a toolbox on these CUTS. The 3000 series uses a cheap plastic tool box mounted by the loader brackets.
   / Bit the bullet on a 4720 #10
Sounds nice-but just a thought- the CX has LESS lift capacity than the X. You do have better rollback angle and self leveling is nice- just think about what's most important to you.
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
