What kind\grade hydraulic fliud to use
   / What kind\grade hydraulic fliud to use #1
Kenfranklinl
massachusetts
ford 1200
Hi everyone. Can someone tell me what kind\grade hyraulic fliud I should use for my Yanmar 66o 3pt backhoe. I was given some hydraulic fliud that had water in it now I have to drain the tank and but in new oil. Thank god I did not start it up.
   / What kind\grade hydraulic fliud to use #2
Ken,
Nobody paying attention to you..??....I thought you'd be inundated with responses.....:laughing:
Not sure what hyd system you have....?? PTO Pump and separate reservoir..??...Any good AW-32 hyd oil or tractor/trans fluid would work (as long as it doesn't have water in it....:thumbsup:)
   / What kind\grade hydraulic fliud to use #3
Unless the water has been emulsified with the hyd fluid, I would suspect it was on the bottom of the container, or reservoir/tank. Once it goes through the pump and several cycles, it would be emulsified.
Thanks Bill, Ya its a PTO with resevoir. I got the oil from my brother who has been a heavy equipment operator for about 45 years. the 5 gallon container got water in it some how and i did not notice it until I pumped about a gallon in.
The Piston you rebiult for me looked great and went together nice and easy.
Thanks for your help again, Ken
   / What kind\grade hydraulic fliud to use #5
Thought you might find this interesting while I was doing a google search on your Yanmar....
Yahoo! Groups
This could have been you......:laughing:
Yea, those PTO Gear pumps can handle any good quality hyd oil .....doesn't have to be the super premium stuff......
Ya, I found that also today. But not much of any info out there on the 660. Thats why this forum is so great because of the knowlege of the members.
   / What kind\grade hydraulic fliud to use #7
utf fluid is likely fine..
soundguy
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2016 GREAT DANE 53’ REEFER TRAILER (A58018)
2016 GREAT DANE...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Lamar Trailers 45ft T/A Pipe Handling Trailer (A55973)
2014 Lamar...
