Bx2350 starts but dies w/ Go Pedal
   / Bx2350 starts but dies w/ Go Pedal #1
Slice
Houston Texas
Kubota Bx 2350
Installed new lights on sunshade and ran all new wires to battery, switches etc,
I found the 12 v power and ground wire on back in wire loom and hooked up an external 12 plug in outlet for sprayers, spreaders etc,
No isssues before wiring lights,
The issue is the tractor will start fine but with the go pedal forward or back it dies, like a saftey switch is catching it,, i did not unplug anything and rechecked all connetions,, all are good,,,, checked seat switch seems to be okay
thanks
   / Bx2350 starts but dies w/ Go Pedal #2
You did check the seat switch? I had the same problem just a week or two ago...The wire to the seat switch came unplugged...
   / Bx2350 starts but dies w/ Go Pedal #3
were you able to shut off tractor fine with key? chances are you blew a fuse. Another possibility is that you said you check the seat switch- not seat switches. I haven't looked at the 2350, but I think there are 2 on the 2350 seat. gray switch and black switch.
starts and shut down is fine like normal just when you push pedal it dies,,, forward or reverse checked and jumped out seat switch the one that closes with your butt on it.. still same checking for blown fuses..... just a dang ole head scratcher
   / Bx2350 starts but dies w/ Go Pedal #5
Did ya check the PTO???
I retraced all my steps, and knew it had to be something i did as it all worked fine before, found a wire that did not crimp correctly, it was a hot wire feed to the little relay on the back of the tractor below the seat and above the adjustable top link, dont know what it does but without power it wont allow the tractor to move... all is well now thanks to all that pitched in....
   / Bx2350 starts but dies w/ Go Pedal #7
Well, I was going to vote for the seat switch. Glad you found the problem.:p
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
2007 Chevrolet Silverado 2500 Ext. Cab Pickup Truck (A48081)
2007 Chevrolet...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A49346)
2016 Toro...
2018 Lexus IS300 Sedan (A48082)
2018 Lexus IS300...
