What tractor to buy in the 95 to 110 hp range?
   / What tractor to buy in the 95 to 110 hp range? #11
EFI usually means electronic fuel injection? Do you mean you want an electronically controlled diesel? Not too many common rail diesels at that price point yet.
I got my MF 5455 with 4wd, loader and cab for that price, but had high hours. Open station would get you low hours. I've seen JD's around that price, 6000 series open stations, low hours, good shape. Likely find a Case JX/ NH TL near that price.
What dealers are nearby for parts?
I dont really need efi.
   / What tractor to buy in the 95 to 110 hp range? #13
I was looking at JD 5425 & 5525s 4x4, loader, and power reverser. All were in the high $30s.
Then I started looking at JD 6X10, 6X15 & 6X20 series and found one under $30K.
Bought a JD 6415, open station, mfwd, power quad, power reverser, 540/1000 PTO, joystick and mid valve, 2 rear SCVs and a JD 640SL loader.
   / What tractor to buy in the 95 to 110 hp range? #14
Good because I don't think there are any gas tractors made in that size since EFI has been fitted to gas engines lol.
   / What tractor to buy in the 95 to 110 hp range? #15
i like 55xx deere's if you get the rear cast wheels plus weights and the power reverser . also mccormick's c70 through c105. older blue tractors that have ford on them .older case ih tractors that became mccormicks.older 50 55 deere's. those would be my choices.
   / What tractor to buy in the 95 to 110 hp range? #16
   / What tractor to buy in the 95 to 110 hp range? #17
"1990 FORD 8210 II Tractors - 40 HP to 99 HP For Sale At TractorHouse.com"
That Ford is hard to believe. But, if an original one-owner as stated, what a cream-puff......
2016 PETERBILT 389 (A53843)
2016 PETERBILT 389...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55218)
2023 NEW HOLLAND...
2006 BOBCAT ZHS 435 FAST TRACK EXCAVATOR (A52705)
2006 BOBCAT ZHS...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
Tradewinds Power Unit (A50120)
Tradewinds Power...
