Trailer mover
   / Trailer mover #1
duckhunter27
Gold Member
Dannebrog , NE
Bobcat CT 335
fast and easy trailer mover my rear bobcat blade has holes for differant angles i just hand screwed a trailer ball in center hole just remove if i need to spin blade throw ball in tool box works great.
   / Trailer mover
Dang I forgot the pic's. this was just a fast and easy way of moving trailers. And it work great.
   / Trailer mover #4
Wow ! that's to easy. Never thought of that, my rear blade has the same setup with the holes on both sides.
I'd probably flip the blade around for a little less weight on the 3pt.
I think my rake is the same as well.
JB.
   / Trailer mover #5
JB.
I was wrong, mine is different, could still do it with the top frame hole when the blade was reversed though.
The rake would not work, holes are on the sides.
JB
   / Trailer mover #6
Finally, an impliment that comes with a trailer hitch! That's reason to buy one right there..
   / Trailer mover
Yeah couldnt belive how easy it was, I just happened to have blade turned backwards but on mine it will work either way I just hand tighten trailer ball so i can remove it easy. I was always going to weld a reciver hitch on my box blade but guess now i dont have to . I also keep ball in tool box so i can put it on pallet fork if i want to agian i just hand tighten.
Adams 5T HC Spreader (A55301)
Adams 5T HC...
2010 Chevy Express Van (A47477)
2010 Chevy Express...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56129)
2019 FREIGHTLINER...
CFG Industrial XZ20R (A53316)
CFG Industrial...
