   / Harbor Freight Tools that don't suck #1,701
Good Afternoon & Happy Easter Guys,
I opened up my sunday paper today, and I see that Harbor Freight has opened up a store on the Boston Post road in Orange, Ct. For anyone in the southern Ct area you might want to take a look...
They did have a small light duty 12 v winch for $39.95, that I wanted to look at, was thinking I could mount it on the front of my trailer and pull my heavy wood working equipment up the bilco stairway onto the trailer and transport to my barn in Vt...
Just thought I would mention it for anyone in the vicinity...
Have a great Easter ! :)
   / Harbor Freight Tools that don't suck #1,702
They also opened one up in southern NH but still none in VT yet.
   / Harbor Freight Tools that don't suck #1,703
Ok, went out and got the 2 ton shop crane mentioned a few posts earlier. Cost was $156 out the door after the sale price and the 25% off coupon and the free flashlight.
Got it home and spent 30 minutes putiing it together and I do have to say that, at $156, it is one of the better HF deals and maybe the best deal.
Sure is a lot of metal there for the money. Plus, the product actually works.
   / Harbor Freight Tools that don't suck #1,704
Part of the challenge using the shop crane is the limitation posed by having only a hook as the attachment point. Maybe we could get an expert TBN rigger or bosun to teach us tricks to attach awkward load shapes.
I am not a rigger, but I solved the chalange of skidding large cu yd sized rocks from under my cottage with a 5 ton come-a-long once.
I wrapped the rocks with an old tire chain using it as a makeshift chain net. That ended the slippage issue just fine. We skidded out couple of dozen that way, Also used old sheets of plywood as skid base, sorta like a sled.
   / Harbor Freight Tools that don't suck #1,705
Check "Pep Boys" , Last summer purchased the same lift built by "Big Red" for only $99.00.
Desert
   / Harbor Freight Tools that don't suck #1,706
Desert
Is that the one ton or two ton model?
HF sells the one ton @$99 every now and then.
   / Harbor Freight Tools that don't suck #1,708
   / Harbor Freight Tools that don't suck #1,710
I bough this nail magnet and it has been a great performer. I would recomend that if you are going to roof a building or some such and pick up the nails afterward cut the grass very low before you start.The magnet hs trouble pulling nails through the grass.
HF nail magnet
The one I purchased is 24" though and for working on rough ground I think it is better.
CYCLE KNIVES (A58374)
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
Kubota L4701 (A53317)
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
2002 Ford F-650 Landscape Flatbed Truck (A56858)
2002 Ford F-650...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
