OP
boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,829
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
spent an hour one night, moving a little bit of dirt.
spent another night a couple hours moving dirt.
finally had a full day of work 14 hours worth *looks exhausted*
spent most of morning finishing out a 70 foot line of dirt to top side of the hill. once i got that finished, i got 3, 20 feet long, 12 inch diameter culverts connected together today. with some silicon around the pipe / band clamps.
i thought oh ya, finally! be able to just move dirt from high side of hill and fill in a little wash out channel the creek has eroded away, and use backhoe to compact it down and level things out. and push the pipe down.... needless to say. once i started moving dirt, i ended up just moving dirt from high to low side of the hill.
after i took another look, i figure i best go make another 70 feet long pile of dirt on top of the hill. or i will not have enough dirt. to cover ends of culvert. and make sure water is directed through culvert. so spent majorty of rest of the day and night making that pile.
i could of most likely made better time, but the smaller size wheels on front of tractor and just a little bit of wet ground and heaped full FEL = front tires partially sinking into the ground and making ruts every where. and with just enough hill between were i was getting dirt and placing it. caused 3rd gear to be useless. so i was stuck with 2nd gear, and felt like i was on a bucking bronco the entire time.
(( i so wished i had a lo/hi gear lever so i could have 8 speeds vs 4
(( I love shuttle shift!!:thumbsup: ))
(( i hate shuttle shift as well, being this is a used older tractor, there be more slipping of the plates, slipping of plates = loss of power to the wheels
, though i can live with the slipping, shuttle shift was / is a requirement :thumbsup: at least for me. ))
i took these pictures around 6:30 / 7pm tonight. just as sun went down, it was to dark at 9pm as i finished the last bucket full of dirt to finish out the 70 foot high side pile of dirt.
EDIT: helps to upload correct photos *duh*
