Keep mice out of equipment
   / Keep mice out of equipment #1
Tomas
How do you keep mice out of your equipment during winter? I have put out tons of poison, but the mice have chewed wires and diabled my tractor, backhoe and dozer.
Any suggestions???
Thanks
   / Keep mice out of equipment #2
Any suggestions???
Thanks
Mothballs. Seriously. The little critters will die if they try to stay in a enclosure with them, and they avoid the smell like the plague. I find when I put put stuff away in the fall, they usually last most of, maybe all, winter. They help with chipmunks/vols or whatever as well. AND (drum roll, please) they're cheap! Hang little bags (old socks, whatever) of them around the equipment....
   / Keep mice out of equipment #3
i agree moth balls help but i still get some mouse acttivity just not near as bad also bounce dryer sheets seem to help alittle .I also have traps set i use a design i ran across years ago plastic bucket with a rod threw top. drill 2 holes in top of bucket run small rod threw and in the middle of bucket run the rod threw a pop can then threw other side of bucket can should spin freely no put peanut butter on ends of can and make a ramp or set close to something so mice can climb up they will climb out on rod step on can and it will dump them in bucket. ps put about 2 - 3 inches of water anti-freeze mix in bucket wont freeze andhelps with smell.
   / Keep mice out of equipment #4
I've had good luck w/WD40.
   / Keep mice out of equipment #5
Any suggestions???
Thanks
I've heard that they don't infest an engine compartment if you leave it open. I don't know if that is true, but I wintered my L4200 in my barn for the first winter this year. As a superstitious move if nothing else, I left one of the engine side-panels off of my L4200, and it was mouse/rat-free all winter (and there are a zillion of those nasty things in my barn).
I also plan to build a 5-gallon bucket trap to kill as many as possible - they seem to work great.
JayC
   / Keep mice out of equipment #6
Moth balls didn't work for me.
But chlorox bleach sprayed on the area works for me, both for mice coming back to nest in my tractor ----------as well as the raccoons that come on my deck to dump.
I put mouse poison out around my shop and tractor shed year around. A fresh packet every two weeks or so. Also, keep some traps baited and set with peanut butter for the strays that get past the poison bait. I essentially have little to no problem.
I have tried some of these in the past, but will try them ALL together.
Thanks for your input.
Tom
   / Keep mice out of equipment #8
Get a good mouser cat. Set him up with a nice place to sleep. Give him some food and water. Just make sure it is fixed if you get a female cat or you will have more kittens than mice...
I would gladly put a cat in the barn, but I don't live there and am sometimes not there for several months.
   / Keep mice out of equipment #10
Oh I didn't realize that Tomas.. Either the cat would get good at mousing or the mice would be feeding on the cat
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A51039)
John Deere 1110...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
