New Holland 845 Hay Baler
   / New Holland 845 Hay Baler #1
tractorboy5500
Gold Member
Conroe TX
Mahindra 5500 4WD, 275 FEL
I bought a NH 845 hay baler last week for $500 from a friend that wanted to get out of the hay work, It worked last season he said and have some wear and tear on it. When I got it home I cleaned it up and hooked it to my tractor, it all works like it supposed to. I got to looking at all of the moving parts, 2 out of the 7 floor chains needs replacing and 5 out of the 7 chain trays need replacing and the floor bottom, I have the metal for the floor, just in the process of ordering the other parts, all of the drive gear looks and operates good, and the apron chains look in good shape, I will take the tension off to check all of the bearing, just havent got to it yet.
This hay baler has chains, not belts, any tips from the pro,s out there??? thanks
   / New Holland 845 Hay Baler #2
keep the floor chains tight and oiled and dont fall off the tractor are u will be baled up i have seen these little balers pick up some pretty heavy stuff
I tried to tighten them up, with the adjustment screw, but two of the chains had to much wear on them, they were all loose, while I have it torn apart, I have been working on cleaning and painting the underbody, just have it primed for now till I get some paint from TSC.
I have a manual tie, I never used one but I guess after a few times or wrecks I will figure it out.
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2014 Ford F150 Pickup Truck (A53422)
2014 Ford F150...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2025 IR IRE20 Mini Excavator (A52377)
2025 IR IRE20 Mini...
