KYErik
- Joined
- Dec 2, 2005
- Messages
- 904
- Location
- South central IL
- Tractor
- 1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I saw an article about one of these in Mother Earth news and decided to build it. The ball bearing rollers are rated at 900 lbs each. The main frame is made of two 5"X5" red oak beams and five black locust 2x6's (all sawn with my home built bandmill) covered by half inch plywood. I really need to build the sides up taller, right now they are only about 16 inches and this limits the amount of dirt that can be loaded. There are two pieces of channel iron bolted to the pickup bed that act as tracks for the front rollers and one piece of channel iron bolted to the passender side beam that acts as a guide for the rear of the dump bed.
That old beat up truck is a 69 chevy. The proceedure to dump is as follows.
1. Drop the tailgate while on a level surface ahead of where you want to dump.
2. Shift into reverse and approach the spot where you want to dump the load.
3. Apply the brake firmly so that the bed has just enough momentum to roll out of the truck bed and then the back drops over center. The 2 straps catch the whole bed from rolling out onto the ground. I would guess that too quick of a stop would cause the straps to beak and the whole apparatus would come out of the truck.
4. To reset it- lift the back of the wooden bed (not too difficult- maybe 60 lbs) and roll it back into the truck. Then latch the tailgate and load it with dirt.
So far I have only dumped one load of dirt, but it worked very well. I can load it with my old backhoe and then simply dump the load without worrying with hydraulics etc. My total investment here was about $50 (the casters were on clearance at TSC for $7 each)
I realize I have raised my center of gravity and wouldn't want to drive this on a slope.
