new craftsman GT6000 Kohler eng issue
   / new craftsman GT6000 Kohler eng issue #1
SPIKER
Elite Member
Ohio, Jeromesville, Ashland County
Jinma 284
Hi All:
just got my NEW 54" GT 6K with 54" deck & the 26HP Kohler Commander Pro engine. The engine seems to be running rough & has a sound I would say is a tight/loose valve issue.
It runs OK at speed but seems to have a sound I would best describe as a exhaust leak or a valve staying stuck open slightly almost a POPPING type sound. Also it seems to have less power than my 20HP briggs and it is 10 years old. First time mowing this week I ran it thru some 8" grass & it barely cut it at a crawl I had to stop often to let the engine pull back up some RPM. I called service and have them coming up to check on it but that will not be until near end of month. I thought it would be better to ask here and see if anyone had thoughts & ideas, I dont want to keep running it if there could be some damage that could happen. I got out my old 20HP 46" mower and went right thru the grass with a week more growth on it and didnt have an issue at all it mowed fine. The woman rode the NEW mower and had same issue I had had to keep slowing down & let engine clear up.
not smoking or burning oil seems to be right oil level too. I am not pulling plugs as it is under warranty and dont want the tech to say I did something... It will take them till end of month to come look at it.
thanks for thoughts comments and items to look at. Should I park it and only use the old one, (trans-axle is about out of it 10 yrs old Murry / Quality Farm & Fleet unit perliyss .)
mark
   / new craftsman GT6000 Kohler eng issue #2
On my B&S 24hp it was the valves sticking in the guides. It would cause a popping, intermittent rough running and eventually a snapped exhaust pushrod. Had to change the head, and it has been golden ever since. The valves ticked on this head right from new, and I got about 150 hours out of it before I changed the head.
This was on a Craftsman GT5000.
   / new craftsman GT6000 Kohler eng issue #3
Hi All:
mark
It may have a blown head gasket. My neighbor has a similar mower that's about 6 years old. Sears replaced the engine once and i replaced one head gasket twice and the cam once. Hasn't had any issues in a couple of years. Has around 700 hours on the machine.
Jim
Thanks guys so far: I have a service tech coming out but not until end of the month so I will need to mow and will try using it as is and maybe take it back for an exchange...
Mark
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A52377)
2012 Chevrolet...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
2002 International 9200i Truck (A55218)
2002 International...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
