Poll: Your satisfaction with your HST transmission
   / Poll: Your satisfaction with your HST transmission #71
I've got two Kub HST's... A Grand L (purchased on 2002, now at 1000 hours), and a BX (purchased in 2005, now at 600 hours). The L has been nearly perfect in operation (I'll say 9.5). The BX I'd have to knock back a bit (say 8.5), only because it has a mechanical actuated control for the pedal instead of the servo-operated one as on the L. Doesn't have the same flawless return to neutral action of the larger tractor. Never been a problem, but it requires a bit more attention when you're using it.
No mechanical problems with either unit; they work now exactly as when new. We do our own maintenance... changing the HST fluid is costly but not difficult.
   / Poll: Your satisfaction with your HST transmission #72
I'd have to give mine a rating of 9.5. Have over 500 hours on my 1620 and have always liked the HST. My tractor has the heel-toe pedal, which many people seem not to like, but I find it very easy to use. When first purchased, I primarily used the tractor for FEL and backhoe work. In the last couple years I've been purchasing and using a greater variety of implements; even took a stab at using my two-bottom plow and disk harrow last year. The HST seemed to work fine. The only comparison I have is a few Ford 8N's and 9N's I've used in the past. I'll stick with the HST!
   / Poll: Your satisfaction with your HST transmission #74
I have a 07 3940 and I rate it at 9.5. The whine is noticeable but tolerable thus a few tenths off. I use mine for plowing, mowing, clearing, and tilling and it's done everything I've asked of it.
DanKTX
   / Poll: Your satisfaction with your HST transmission #75
My (4) field tractors are all gear, and I wouldnt want a hydro for field use. For on the lawn, I have one hydro and one gear. These two machines really demonstrate the strengths/weaknesses of both transmission types. They are both the exactly the same hp, but the mower is about 20% wider on the gear tractor. In spite of that narrower mower, I can usually get the lawn cut faster with the hydro because that lets me perfectly match the ground speed to any conditions. The gear is always a little too fast or a little too slow for conditions. This time of year however, when the lawn needs cutting every 3-4 days, I prefer the gear even on the lawn, because it lets me get more of the engine's hp into the grass. Cutting thick spring grass takes a lot of hp. So right now, on a scale of 1-10, for cutting my lawn, the hydro gets a 5 and the gear gets a 7. When the grass slows down in the summer, the hydro gets a 9 and the gear gets a 5. Where a hydro excells, just think of the letter "L" : Lawnmowing, Loader use, and Landscaping.
   / Poll: Your satisfaction with your HST transmission #76
I will give it a 9.8, I like the control but sometimes I wish I could put a little more power to the ground but realistically when the wheels are spinning more power doesn't help. I do spend a lot of time in the woods in tight quarters, I would hate to be messing with a clutch.
For the record I currently drive an automatic, but I love driving stick and have been toying with the idea of a Mustang with stick for a mid life crisis. Unfortunately I spent my mid life crisis wife credits on a green tractor with a top speed of 13 MPH.
   / Poll: Your satisfaction with your HST transmission #77
Is there a trannie that has both like a few of the new foreign cars. Is a GHT, glide shift hydrostatic offer more that a straight hydro. I love gears but got hydro's (several) for easy of future use by my wife. Two hydro lawn cutters, john deere Sabre 25hp and e-hydro so she someday may remove snow form the drive. She also wanted and I got her a hydro 60" zero turn.
   / Poll: Your satisfaction with your HST transmission #78
Well....I see no one has voted a 10 yet. I can kind of see why, since most replies are people with Kubotas,Kiote's,New Hollands, etc. So ....I vote the Deere HST a 10. :D
   / Poll: Your satisfaction with your HST transmission #79
For my two tractors with the ehydro tranny I would rate them as a 9.5 the smaller X749 I would rate it a 9.0 because the pedals don't feel as good as the ehydro's.
2019 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2019 Allmand Bros...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
EXCAVATOR BUCKET ATTACHMENT (A53843)
EXCAVATOR BUCKET...
