What Driveway Alarm to get?
   / What Driveway Alarm to get? #11
I've got a Dakota with the "metal detector" and it's great. Lithium 9v battery is entering its 3rd year.
False positives - walking over the buried sensor with a chainsaw or aluminum ladder will set it off.
False negatives - large trucks backing trailers up the drive go so slowly that it doesn't go off.
Other than those two scenarios, it's accurate and reliable.
I ordered the Dakota alert 2500. Hopefully it will get here in a few days. Will see how it does. Thanks for all your input.
   / What Driveway Alarm to get? #13
I had the Dakota 2500 and 3000 on my drive. Neither system worked reliably at a distance of 500'. Dense woods and hill. After mucking around for a couple of years, ended up with the MURS which works perfectly. I wish they offered the MURS with updated receivers, different chimes, etc. but Dakota said they will not update the MURS system. It is what it is. Batteries last forever.
   / What Driveway Alarm to get? #14
Mine has a problem with the batteries going dead fast in the cold winter. In the moderate weather the batteries in the sender unit last about 2month. I do not know who made it, bought is at Lowes about 5years ago.
   / What Driveway Alarm to get? #15
I've had the Reporter for 7 years now, and no complaints. I'm impressed how long the batteries last and how well the two sensors pick up the vehicles and yes...deer and turkeys :D
I added a third unit to keep track of just the animals near the woods and really enjoy having a heads-up when they move around.
A few misses, but that seems to be certain types of cars. The low, sleek ones that are "stealth" cars. :) I've been surprised this reasonably-priced system has lasted as long as it has. I'd replace with another Reporter if/when this one gives up.
Certainly a benefit to know when a vehicle moves up the drive. With the two sensors about 120 feet apart, we can usually tell if the alarm signal is an animal or a car because of the second signal. The furtherest sender is line-of-sight and about 350'.
   / What Driveway Alarm to get? #16
I purchased the Chaimberlain replacement and put it in the same spot. It didn't work, missing probably 1/3 of the cars. It would get a car once, then miss it the next time.
A spike belt should not miss any and would definitely keep traffic to a minimum!!:laughing:
   / What Driveway Alarm to get? #18
...you will be sadly disappointed as the "new" version is not nearly as good as the old one , and the "new" sensors won`t work with the old reciever as they work off of different frequencies !!!
I just went through the same thing when we moved to our new place...luckily i was able to find some new "old" ones on e-bay.
Although it worked nearly flawlessly at our other home ,for about five years, it`s hit or miss here , and I may look into the Dakota system in the near future.
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52128)
Gooseneck...
John Deere 270 Compact Wheel Loader Skid Steer (A50322)
John Deere 270...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
Bef-Co Finish Mower - INOPERABLE/PARTS ONLY (A52128)
Bef-Co Finish...
John Deere 4020 Tractor (A50514)
John Deere 4020...
