TPH finish mowers - King Kutter vs. Landpride
   / TPH finish mowers - King Kutter vs. Landpride #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
King Kutter 72" rear discharge vs. Landpride 25-72 side discharge. Given the choice between the two for virtually the same money... which would you choose and why?
   / TPH finish mowers - King Kutter vs. Landpride #2
Land Pride as the finish on LP has been superior on all the equipment I have seen. My "impression" is that the LP is a bit better quality. Having said that KK, Caroni etc. all make good equipment, both our RFM's are Caroni.
   / TPH finish mowers - King Kutter vs. Landpride #3
I think I'll buck the trend on this one but I have had horrible luck with my LandPride 2560 mower. I have replaced spindles and they did a horible design of the tire system. Part prices are not cheap (probably same price as competition) but in my opinion at least seem harder to find parts than KK. I even took the time to write customer service and the response was basically "thats not typical" "buy a new one" my response to that went unanswered. They have had multiple revisions to parts which implies they know about the issues and improved the product but wanted nothing less than charging full price to existing owners for the improved parts. The cost of the upgrades to the spindles and tires is over $1,000. The deck itsself if very heavy and seems very well made but I seem to suffer a failure at least every 10 hours of use.
This is my first 3PT finish mower but I have a 8 year old Murrary 42" w/cut that seems to work with much less issues.
   / TPH finish mowers - King Kutter vs. Landpride #4
I am also about to invest in my first 3ph finish mower and from the research I have done so far, the one thing I have concluded is rear discharge is tantamount to less windrow effect and a more even distribution of the cut material to decompose and feed the new grass. :D
   / TPH finish mowers - King Kutter vs. Landpride #5
In fact, side discharge is out. Apples to apples,as well,as they say!
   / TPH finish mowers - King Kutter vs. Landpride #6
Take a look at First Choice.
Very good quality/value for the $$.
   / TPH finish mowers - King Kutter vs. Landpride #7
I have used a Buhler 84" for about seven years..........not the first problem....just my $.02.
Gene
   / TPH finish mowers - King Kutter vs. Landpride #8
If you really want a finished look with even grass distribution a flail mower with finish blades is the way to go.
That is a bit off topic but it is something to consider.
   / TPH finish mowers - King Kutter vs. Landpride #9
I have a LandPride FDR1560 rear discharge finish. With new blades on it the cut is fantastic.
   / TPH finish mowers - King Kutter vs. Landpride #10
I own a Woods 72" rear discharge that is built like a tank, but I also own some Land Pride attachments as well and you can not go wrong with either. I can't make a comment about others as I have not owned them.
DevilDog
2024 CATERPILLAR 299D3 SKID STEER (A51242)
2024 CATERPILLAR...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
Loader with IH Brackets (A50515)
Loader with IH...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
