In-axle brake wires
   / In-axle brake wires #1
MillWeld
Gold Member
Durham NC
Ford 641
I'm still new to trailers and axles but here is a simple observation on the axles I have used (MH and commercial, AL-KO).
Axles that route the brake wires thru the tube have the access holes in the side of the tube. This allows rain and splash to get in and not get out. Why aren't the holes on the bottom so that the water drains out?:confused: I've routed conduit acound my trailer giving access to power on both ends of the axle, removed the in-tube wire and welded it closed.
Bob
   / In-axle brake wires #2
Bob
I put silcone around the holes on mind, or what ever you perfer, that would help.
   / In-axle brake wires #3
Not sure. I have personally only see one axle fail and it was a MH axle. I have seen burnt up spindles, bent spindles, ect but only one tube failure.
Chris
1454 (A57192)
1454 (A57192)
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
1993 Generac Olympian 93A 100kVA Towable Diesel Generator (A56857)
1993 Generac...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
JOHN DEERE HOPPERS & CULTIVATOR FEET, MISC (A58374)
JOHN DEERE HOPPERS...
