Montana 3040 Hydraulic warning light
   / Montana 3040 Hydraulic warning light #1
orwinlaw
Montana 3040
The hydraulic warning lamp on my Montana 3040 has come on. I replaced the hydraulic filter and replaced the hydraulic oil but the lamp remains lit. Does anyone have any idea what the problem is? Is there something that needs to be reset after I changed the filter?
   / Montana 3040 Hydraulic warning light #2
I do not think there is anything to be reset, I have never had to and changed the filter 2 times now.
I would be looking at the wiring for the switch that turns the light on. The switch is right by the filter and the wires are kinda in a bad place for stuff catching on them. If you unplug those wires will the light stay on? If it does the wiring is grounded or contacting eachother somewhere. If id does not stay on I would guess the switch is bad.
You might want to try posting this in the Montana forum.
Thanks for the tip./ I will check it out
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
2014 PETERBILT 388 AUTO TRANSPORTER (A52576)
2014 PETERBILT 388...
2017 Ford Explorer (A51694)
2017 Ford Explorer...
