Attachment advice
   / Attachment advice #1
nspec
Southern Rhode Island
Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
I'm starting a new vegetable plot, about 100 x 40. Over the last 2 years, I've cleared and stumped it. I've got a really nice plow and tiller and just seeded buckwheat for the first time to help add some structure to the soil.
I'm looking for an implement which I can use after the tiller. The tiller fluffs things up almost too well. It leaves 5' wide humps with rows in between that are more settled/packed from the edges of the tiller and a little of the tires.
I was thinking of running through with a chain drag just settle things out a bit and make it real uniform. I also want to use something on flat ground to cover seed which I broadcast - buckwheat, rye, etc..
I don't own a chain drag, and can hardly justify the cost for such a limited use. I know it would work well, just wondering if something else would also work. I would be buying a cultivator at some point. Thinking that would definitly take the fluff out and settle things some, but as for covering the seed?
I made a drag out of chain link and it worked just okay. I also dragged a board, but it only got the high spots. When I drove through the fluffed up soil, I made tire tracks about 4-6 inches deep and the board would miss those. See what I'm getting at? Sorry to be long winded, just looking for any thoughts or ideas.
   / Attachment advice #2
When you till do you have your tiller offset to one side to cover one wheel track? If you do that and always work toward the opposite tire you should leave a nice level field.
   / Attachment advice #3
we started out much the same as you.
We have used a disc in the past to lightly disc in broadcast seed with decent results.
Also made light passes with the tiller to till in seed. I tried this with oats and cow pea mix last year. The stand was good and performed well as a cover crop between rows.
Its probably not the best or most effficient way but you have to use what you have.
   / Attachment advice
I probably wasn't clear. My tiller completely covers my tire tracks. I'm tilling deep, and the tiller works quite well. At the very edge of the tillers track, there is a runner. This narrow strip doesn't fluff up like where the tines are. It doesn't matter if I overlap or not. The result is 5 foot fluffy beds, with narrow strips in between that are not fluffed.
Not a huge worry for the vegetables, as the beds will be hilled. The problem arises when I want to seed a cover crop. In order to get good seed to ground contact, I would like to lightly cover the seed which I broadcast. With the ridges, an ordinary drag will miss the low spots. I would like to smooth the whole field, settle the fluff a bit, then cover up the seed lightly.
I like the tiller advice to lightly cover the seed. I was worried about beating up the seed too much.
Several ideas: Cultipacker, chain drag, cultivator
All would probably work well. I just don't want to spend a ton of money just for once a year fall cover crops, you know what I mean?
   / Attachment advice #5
seed costs would be lower with a drill and cultipacker.
But with the low acreage you and I are doing seed is probably cheaper than steel.
   / Attachment advice #6
I have had good luck with the following procedure:
1) Use our CUT tractor to till, using a PTO tiller.
2) Use our lightweight lawn tractor , rake the surface, creating grooves in the soil for the seeds to drop into. This is done with the mower deck removed so it doesn't get hung up in the fluffy soil.
3) Use the lawn tractor drop spreader to spread the cover crop seed.
4) Use the lawn tractor with lawn roller to pack everything and get soil/seed contact.
-Jim
   / Attachment advice #7
Edited for better truthyness:
We have had good luck with the following procedure:
2) Use our lightweight lawn tractor with lawn roller to lightly pack the surface. This is done with the mower deck removed so it doesn't get hung up in the fluffy soil. Weight can be adjusted to get desired result.
3) Use the lawn tractor to rake the tilled surface, creating grooves in the soil for the seeds to drop into. It's a 48" wood 4x4 with 6" long 3/4 dowels space 4" OC (a seriously failed landscape rake build for the CUT that I hid for a year before I could bear to look at it again - cut-down to fit the smaller tractor).
4) Use the lawn tractor drop spreader to spread the cover crop seed into the grooves.
5) Use the lawn tractor with lawn roller (again) to pack everything and get good soil/seed contact.
-Jim
   / Attachment advice #8
I small section of chain link fence will work to level it out. Not sure how it wil work for the seeds, though. A lawn roller might work.
   / Attachment advice
Sort of the cultipacker idea. I like it. Rollers and rakes are cheap and easy to find.
   / Attachment advice #10
Exactly!
If I ever find an affordable cultipacker nearby, I'll be all over it like engineers on free donuts.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
1980 Gleaner F2 with heads (A56438)
1980 Gleaner F2...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
207282 (A52708)
207282 (A52708)
