Stump Grinder
   / Stump Grinder #1
reed52
Member
Southern IL
Kubota BX2400
I have a BX 24. Is there a stump grinder that will work on this tractor or is it too small?
thanks,
Reed
   / Stump Grinder #2
I think the woods tsg50 would work for your tractor. It requires 15-50hp, so you are right near the minimum but it should work. I say see if you can get a demo for it on your tractor, to see how well it works.:2cents:
   / Stump Grinder #3
thanks,
Reed
How many stumps do you have and what size? It might be worth it to rent a grinder or just use your BH. I have removed many stumps with my BX25.
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2001 Ford F-350 (A55788)
2001 Ford F-350...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
Galvanized Livestock Gates - 4FT x 18FT (2x Gates) (A55301)
Galvanized...
