Grapple Hookup Questions
   / Grapple Hookup Questions #1
chamjoe
OK Kids, Just took delivery of my new ride (CK35HST)
I'm not new to tractors, but am a hydraulics novice. I had the dealer install a rear remote in anticipation of a grapple. I plan on getting a light gator grapple.
But some Q's first
The rear grapple is a 1/2" QC and the new grapple will have a 3/8" hose. How long does the hose need to be in order to reach the rear remote? I came up with 12' measuring but would prefer to be exact. And for the bigger question. What is the easiest way to go from 1/2" to 3/8"?
I know these are fairly dumb questions but I would prefer to order the thing correctly the first time.
   / Grapple Hookup Questions #2
kennyd is the hydraulic guru here for good info on your questions. But 1/2 to 3/8 with a reducer should be available. A number of different options. Might check out surpluscenter.com for some commonly available fittings. They are a TBN sponsor too.
   / Grapple Hookup Questions #3
use a garden hose, tape it to the bucket where the grapple hydraulic lines are, run the rest of the hose under the tractor... then raise the bucket all the way up and curl the bucket down. Add a bit extra...
   / Grapple Hookup Questions #4
Thanks BT:eek:
For the length, the best way to measure is to tie up a garden hose or similar tubing from the front to the rear with zip/wire ties and the mark the length needed with tape or a maker being sure to leave a little slack.
The 12' number you quoted sounds a little short to go from the rear, under the tractor, up the loader mast and then down the arms.
Also, you only really need 1/4" hose to run the grapple since it uses very little flow to operate. The smaller hose is cheaper and easier to route as well.
Gator often ships flat-faced skid-steer style couplers with the grapples since they do not fully understand the CUT market. When I bought mine (from Markham at the time) I chose not to get any hoses or QD's from them so I could measure the hoses needed from the grapple to the loader accurately, and used 1/4 hose.
There are plenty of adapters available to match up any combination you will need.
Are you going to add QD's at the loader so you don't have to remove the hoses to remove the loader?
   / Grapple Hookup Questions #5
Exactly. Make sure you give a nice generous curve around the bottom of the FEL post so you don't kink the hoses too. There is no real downside to having an extra foot of hydraulic line as it can easily be coiled and ziptied out of the way. I also like putting on a 90 degree adapter on the lines from the rear remote so you don't have to leave the hoses sticking out the back in order to make a gentle bend there either. Once you get the real hoses, start at the rear connectors then pass the hoses over the left rear axle, under the operator station (zip tie as best you can up to the platform) then up the left FEL post and down the FEL arm. Zip ties work well functionally but there are nicer looking hose clamps you can mount if you are handy with a welder or don't mind a little screw hole here and there.
If you are getting a Gator grapple make sure they provide Pioneer style fittings. 3/8 is ideal for the grapple but adapters are easy to get if you get 1/2 inch. You will need 1/2 inch Pioneers for the rear remote. I'd suggest you have both male and female at the grapple end so you don't get mixed up reconnecting and also so you can snap them together to keep them clean when off the tractor. You'll need two males for the rear remote connection and the easiest way I know to keep them straight is to put same color zip tie on the rear remote and the appropriate hose.
Thanks BT:eek:
thanks, I had assumed it would already come with a QD from Gator on the grapple end. What do you recomend, tell them to include a hose the length I need or just tell them no hose?
What is pioneer? Is that the same as the "flushface" still a bit confused on the right connectors.
Hydraulic Quick Disconnects > Discount Hydraulic Hose.com
   / Grapple Hookup Questions #8
You say want to do it correctly the first time-your off to a good start.
In my case I used four sets of hoses to do that on my NH TC40S.
Two hoses from the rear remotes to the FEL dock starting with a set of male QCs at the rear female remotes and ending with a set of crimped 90 degree bent tubes that attach to a set of bulkhead unions. You need to build a bracket for the bulkhead unions.
Two hoses from the FEL dock to the edge of the FEL torque tube starting with two sets of 1/2" male/female QCs threaded onto the bulkhead unions, a couple of double hose brackets along the FEL arm run and ending with a set of crimped 90 degree bent tubes onto a set of bulkhead unions. You need to build a bracket for the bulkhead unions.
Two hoses from the edge of the FEL torque tube to the center or vicinity of the torque tube starting with a set of crimped straight fittings onto the set of bulkhead unions and ending with a set of crimped swivel fittings onto a set of 90 degree fittings attachet to a set of bulkhead unions. You need to build a bracket for the bulkhead unions.
Two hoses from the center or vicinity of the FEL torque tube to the grapple cylinder starting with two sets of 1/2" male/female QCs threaded onto the bulkhead union and ending with a set of crimped fittings compatible with your grapple cylinder.
I used 1/2" Pioneer QCs adapted to 3/8" hoses as the 3/8" routs a lot easier than 1/2" hose.
Use a charged air hose if you have one as a measurement tool for your hydraulic hose lengths. When measuring the hoses from the FEL dock to the edge of the FEL torque tube, look at how your tractor's manufacturer created the "S" configuration in the hoses that power the FEL bucket. That is at least how much slack you will also need in them when you raise the FEL.
Don't make up the last set of hoses to the grapple until you have the grapple installed as there is no way beforehand to tell how much slack will be required.
I used the left side FEL arm to run the hoses as the right side was way too cluttered with factory pipes and hoses.
There are several hydraulic shops in my (ag) area and picked the one that felt comfortable-happened to be the closest to me.
I made A LOT of trips back and fourth to the hydraulic shop starting from the back of the tractor with first set of hose measurements with an extra foot or so tacked on and had only the upstream end crimped, went home, attached, detached and back to the hydraulic shop for the final cut to length and other end crimping.
I went into this project as a complete flaming no-nothing hydraulic sub-novice but just put forth ideas what I wanted to wind up with and in most cases the Hydraulic shop guys built it with their expert parts knowledge to my plan. Some will say what I did was a bit of over-build but if you look at various factory installs you will see the same sort of applications that I chose. Apologies in advance to those who have already seen the photos. Have at it at any level you wish but go into it with the notion of only having to buy it and build it once. Good luck.
Thank you very much for the write up! I searched the forum earlier and didn't find your pics. I think I will copy much of what you have done. I like what you did with the short hoses from the grapple to the loader mount. I much prefer to over build something and make it look good as opposed to doing a junk jon and fixing it down the road.
Is crimping hose ends something I can to myself or should I go to a shop?
I'm going to try and order the grapple tomorrow so I can get started ASAP!!!
   / Grapple Hookup Questions #10
Nickel plate has a lot of good points. I disagree with one. Splitting the hoses into two lengths instead of one makes sense only if you will regularly take off the FEL. My first tractor was set up with the split hose configuration which cost almost twice as much (double connectors and double charges for end fittings) and leaves a clunky bunch of connectors to deal with on the FEL post. In three years I never took the loader off so it was a complete waste. With a single length removing the lines when dismounting the loader takes only a minute longer to clip the zip ties under the operator station and probably an extra three or four minutes to replace them. If I were to do it again I'd just use a single length.
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
12' CONTAINER (A52706)
2020 Case 5550 Trident (A55315)
2020 Case 5550...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
