Garage Entrance Slope?
   / Garage Entrance Slope? #1
Gizmo2
New York
JD 2320
Anyone know what a good driveway to garage entrance slope per foot is? My roof will be dumping off over the garage doors and I want to make sure no water is going to end up in the garage without getting carried away with a huge slope.
   / Garage Entrance Slope? #2
If concrete, I'd go between 1/4"-1/2" per ft, favoring the 1/4. For gravel, 3/4"-1" ft. It really doesn't take much to make water move. If you have concrete, during the winter, it doesn't take much (slope)to bust your butt!
   / Garage Entrance Slope? #3
A relative of mine put a linear drain In the concrete directly below where the water runs of his eves. To help keep water from making it in the garage. Thought I would throw that out at you for a idea.
   / Garage Entrance Slope? #4
Also make sure your concrete floor slopes down from where the overhead door seal contacts it. Helps prevent the seal freezing to the floor and blown rain runs away, not under the door. I assumed all flat work guys knew this, but it turned out they didn't and I wasn't there to catch it. :mad:
Dave.
   / Garage Entrance Slope? #5
X2 on the slope. Also top of apron should be about 3/4" below top of garage floor. This will help keep wind from blowing rain in under the door, and if frost starts moving stuff around apron won't end up getting higher than floor height.
Much appreciated, thanks all.
Keith
   / Garage Entrance Slope? #7
Put a gutter on it.
You don't want the rock dust splatter on the garage doors.
You don't want the splatter on the garage floor when working with the doors open.
You don't want the drip on a clean car going in or out.
Is the garage above the surrounding area?
Does the drive slope away or towards the garage?
Goodluck
   / Garage Entrance Slope? #8
Not this much:
   / Garage Entrance Slope? #10
More:
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2019 GALYEAN...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
