200CX Can't get Yellow/Black Hydralic Hoses to Connect
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect
Good idea with just removing the bucked, I will try that next time I mow.
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #12
Put a couple of folds of fabric on top of the coupler and hit it with a plastic mallet or hammer. The fabric is optional if you don't mind hydro fluid showers.
This always works for me, I skip the plastic mallet and go directly to the real hammer (or rock). The cloth or fabric is the step you do not want to overlook. Sometimes working the controls will relieve some pressure.
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #13
Its a darn good idea to be wearing safety goggles when applying pressure to the hose end. When you finally get it pushed in, that fluid may well spray everywhere - with pressure behind it. The first time this happened to me, fluid went right into my eyes. Painful and scary, but I can still see. It isn't worth the risk - use goggles!
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #14
Just curious if you moved your control for the FEL in all directions before you removed it (with engine off)? According to the JD video on line they say you should do that to relieve all pressure before unplugging it???
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #15
The pressure build-up is often on the implement side, so that won't help.
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #16
Thats why wrapping a rag over the QD is very important. Fluid can also be injected into the skin causing gangrene.
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #17
I'm only an amateur..... I've only had mine off once so far...:eek: Do you think it would matter if the FEL was being used and the fluid was hot then you unhooked it? I'm just thinking that pressure shouldn't build up if that was the case....????:confused: Like I said I'm just a rookie!!
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #18
That could make a difference, as well as the loader sitting in the sun and the fluid heating up and expanding.
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #19
Also I know it I take my backhoe off and any of the cylinders happen to settle while disconnected from the tractor, game over.
   / 200CX Can't get Yellow/Black Hydralic Hoses to Connect #20
Just want to say that this thread has been very helpful to me this weekend. Thanks everyone for your input!
UNUSED LANDHONOR LHR-AIW1-1" AIR IMPACT WRENCH (A54757)
UNUSED LANDHONOR...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
CRAFCO INC. MAGNUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGNUM...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
