PTO driven lawn sweeper?
   / PTO driven lawn sweeper? #21
I've thought about taking 2 3' ones and hooking them together. But, there would be a gap in the center and I haven't figured out how to get around that. The other problem with the current ones is that they don't hold very much. I spend as much time going to dump it as I do filling it. It's really bad in the fall with leaves, it fills up really fast.
Add a third one in the center behind the front two. I remember seeing this years ago probably doing school ground work
   / PTO driven lawn sweeper? #22
This is a little off topic, but here's what I did and avoided having to lay out a couple of hundred bucks for a lawn sweeper. I take the riding mower and blow the grass to be raked into long narrow strips, almost to the point if I make another pass it will blow the grass too far to the other side of the row. I then start making passes directly across the row and start blowing the row into a pile by making circles closer to the center of the pile. Each row might take several piles, depending on the length of the row and how much grass you have. What you should wind up with are piles about 3-4 feet in diameter. I then get my rake and load them up in the FEL and dump them in the field. This weekend I did this on about 3 acres and had about 20 or so piles due to the amount of rain and high grass. It only took three trips with the FEL to get them all cleaned up and about two or so hours of work. You can really compact the grass into the FEL to increase your capacity. I found this easier than having to continuously empty the lawn sweeper. Having the grass in a pile already is a timesaver and backsaver.
Last year I was looking at lawn sweepers but saw that most of the reviews for the ones that you could get at big box stores were mixed. I looked at the Parker ones and they were well over $600. I like what I'm doing now better, I only have to use the equipment that I have and I can move quite a bit of grass at one time. Doing it this way I'll never buy a lawn sweeper.
   / PTO driven lawn sweeper? #24
Here is the lawn sweeper I use with my kubota BX2660 and love it. It will even sweep small rocks off of the lawn.
Lawn Sweep c/w 5 HP Engine
Details:
41 inch sweeping width.
5 HP Honda engine.
2 x 3.00 x 4 castering nose wheel.
Offset & straight pull hitches standard.
3 paddle sweeping brush.
Simple single belt drive.
Powder coat paint.
Heavy duty molded hopper.
21 cubic foot hopper capacity.
12 x 6.00 x 6 floatation tires.
Positive sweeping height adjustment.
4" x 41" replaceable brush sections.
   / PTO driven lawn sweeper? #27
No worries, I hope you can find one - being professional level bits of kit they're frighteningly expensive, even second hand.
   / PTO driven lawn sweeper? #28
Details:
5 HP Honda engine.
Powder coat paint.
Hello, I'm curious of your sweeper, I do not know and are interested, could you tell me who is the manufacturer or the site.
Thank you
Ciao, sono incuriosito della tua spazzatrice, non la conosco e sono interessato, potresti dirmi chi è il costruttore o il sito .
grazie.
   / PTO driven lawn sweeper? #30
Thanks, but I think it is only a retailer, I need to know who builds them, almost where buy Westward.
Grazie, ma credo che sia solo un rivenditore, avrei bisogno di conoscere chi le costruisce, praticamente dove le compra Westward.
2016 Nissan Pathfinder SUV (A55758)
2016 Nissan...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
20' Sea Container (A47477)
20' Sea Container...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
