Toro Zmaster 555 hard to start when cold
   / Toro Zmaster 555 hard to start when cold #1
BeezFun
IL
Kubota B2710
It has a 25hp Kawasaki gas engine, runs great once it starts but starts very hard when cold. Starts fine when hot. I changed plug, that helps a little, but not much. Replaced fuel pump because it had a small leak, that didn't help either. Been this way since I got it new. I use stabil in the gas, run it dry in the winter, stored inside. Any ideas?
tnx
   / Toro Zmaster 555 hard to start when cold #2
Sounds like the chock is not working or needs adjusted
   / Toro Zmaster 555 hard to start when cold #3
x2.... typical Kawi engine... hahahaha.. Had a Kawasaki ATV that the choke would either stick open or full closed..... finally just disconnected the stupid thing and choked it with my hand....
   / Toro Zmaster 555 hard to start when cold #4
could be the valves need adjusting. I have a kawasaki utv and it wouldnt start when cold but once it was going it started fine. Turned out the valves were in need of adjustment. I adjusted them and problem solved.
John Deere 2640 2WD Tractor with 146 Front Loader (A55218)
John Deere 2640...
Kubota RTV500 (A47384)
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
