Hello Fred,
A lot of it depends upon where the grease fitting is; if it is in the frame arm of the loader and not the center of the pin you should pound the pin out with a piece of brass bar stock, put the pin in the freezer overnight to shrink it
and replace the original fitting.
The problem is clearances with grease fittings as they will quite often butt the fitting against the pin it self and the grease never gets past the space.
You may be better off just removing the fitting and replacing it with a pipe plug and simply grease on an hourly basis as they tend to skimp on these things (The metal holding the pin is thin and not thick enough to allow grease to travel as the fitting bottom is blocked from allowing grease to pass.
I have never bought antthing from Harbor Frieght my self, but with NAPA and TSC you can retutrn things if they do not work
