Rear PTO switch on L3010 failure
   / Rear PTO switch on L3010 failure #1
Grande
Member
Southern Vermont
Kubota L3010HST
Greetings all,
I have an L3010 with a rear PTO switch that no longer functions. That is to say that the rear PTO is engaged constantly without regard to the switch position. If the clutch is depressed the rear PTO then stops.
Might anyone know what is amiss and what service is required? It's a little disconcerting having a rotary cutter spinning all the time the engine is running not to mention a safety issue.
Thanks in advance,
J. Peters
   / Rear PTO switch on L3010 failure #2
Not quite enough info but your brake on the PTO might be failing.
   / Rear PTO switch on L3010 failure #3
By swithch I am assuming you mean the PTO engagement lever (at least my L3010 has the lever) anyway this has happened to me. the lever uses a cable to engage / disengage the PTO, I had some slack in the cable do to streching in the cable, it was a simple matter of adjusting the cable. Don't adjust to much or you will run into a problem of not being able to start the tractor because you are not in contact with the PTO safety switch ( speaking from expereince here) easy fix unless i am missing something here:)
Thanks, I'll inspect the cable and see if that's the issue.
Indeed the cable was the problem. Issue resolved.
Thanks for the help.
   / Rear PTO switch on L3010 failure #7
I will remember that one - Thanks
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
2015 Ford E-350 Passenger Bus (A50323)
2015 Ford E-350...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
Pitts RGN Trailer (A50322)
Pitts RGN Trailer...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
