Help identifying older discer - with red paint
   / Help identifying older discer - with red paint #11
I've also got one and was using it yesterday. You pull the rope and drive forward to set the front angle and then pull the other rope and back up to set the angle of the rear discs.
How much weight are you supposed to put on these things. Mine was cutting well in the centre but at the outer edges it would not even disc through the tire tracks.
How fast should I be pulling this through the fields.
Thanks
Mike
   / Help identifying older discer - with red paint #12
Thanks
Mike
You need quite a bit weight. I have an old Towner 6.5 ft offset disc that I load with nearly 500 lb of concrete weights. And I pull it fast--5-6 mph with my Mahindra 5525--to get it to work decently.
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
Polaris Side by Side (A50324)
Polaris Side by...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
