jda1961
Gold Member
- Joined
- Jan 31, 2009
- Messages
- 261
- Location
- southeastern west virginia
- Tractor
- 1978 ford 3600, 1964 ford 4000 rowcrop
i got around to replacing the oil out of my steering box with cornhead grease today. it was a bigger job than i thought. getting the oil out was the hard part. had to remove the air oilbath thingy, and batterybox, i needed 3 hand but got it done with 2. once i got it out of the way i took the 4 bolt out where you adjust the steering shaft, not sure how you adjust it or what it adjusts(check pics) but thats the only place you can get most of the oil out. it really makes a mess. i got it all drained out, put back together and pumped nearly 2 tubes of grease in til it was coming out the top somewhere(check pics) so i guess its full. i guess i'm pretty much done with this one unless i run across a power steering set up for it, but other than that its done for now.
