Axle vents to prevent seal leakage?
   / Axle vents to prevent seal leakage? #1
Wacky
West Virginia
2010 GC2610
Why not have the front axles vented on these 4 wheel drive tractors? There must be a reason that I am not aware of. I've done a search and came up with no definitive answer. I was wanting to vent my GC through the fill cap, but it looks like I need a vent on both sides of the axle, or one in the center. I am not willing to drill a new hole, so any ideas, or just replace the seals once they start leaking.
   / Axle vents to prevent seal leakage? #2
:confused: Not sure that is a problem, mine are not vented, and they don't leak.
   / Axle vents to prevent seal leakage? #4
Agreed..... Why would you want to ??? It is not like the pressure up ? :confused:
It depends how warm/hot it gets, pressure being some function of temperature.
After several hours the excess air pressure would probably leak out and everything would stabilize, though warm.
Then the "what if ?" as in "What if you then plunge into a cold puddle ?"
Would cold water get sucked in at the seals ? or would cold air get sucked in if there was a vent ?
I don't know about these particular tractors - - but generally I prefer to have vented axles.
I just changed the oil in the front end. Much to my surprise, after sitting for 4 days I cracked open the fill cap and heard pressure releasing. Now, I am no expert but, I would tend to think that after a while pressure against seals would tend to leak. I would think that after reading all the posts that have a leaking front axle this is a common problem, but why has no engineer been able to fix? When the air and oil warm they have to expand right? Where can it go besides past the seals?:confused:
Yes, but where is it leaking past, or is it just expanding the seals just enough to compensate? I noticed in the winter that just after about a half hour the axle was warm enough to melt snow and was warm to the touch. How much warmer does it get on a hot summer day? I would think a vent ran up under the hood in the center of the axle would probably eliminate much of the pressure.
   / Axle vents to prevent seal leakage? #8
If pressure releases when you open the filler then it seems to me that it is venting the whole axle. Could you drill and tap the filler plug and install a barb fitting for some flexible fuel line or vacuum line? Run the line to a higher spot that wouldn't get submerged in deep water or mud. If you want to protect from dust you could put an inline fuel filter like used on a lawnmower or motorcycle to keep the particles out.
   / Axle vents to prevent seal leakage? #9
Check your filler plug, the cap is the same as the rear end and should vent if not screwed in too tigh.
2008 VIKING TRAILER 40+5 LOADER TRAILER (A58214)
2008 VIKING...
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
2009 INTERNATIONAL 9200I TANDEM AXLE WRECKER (A58018)
2009 INTERNATIONAL...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
