Tape on hydraulic connections?
   / Tape on hydraulic connections? #1
acme97
Gold Member
Cottageville, SC
Kubota L35, Kioti DK50SE
I just ordered a hydraulic top link and the hoses. My question is do I need to put tape on the male connector before attaching to cylinder? If so, what kind? Will standard teflon plumbing tape work?
Thanks
   / Tape on hydraulic connections? #2
Some people use tape, and others use paste. There are some on here that say never use tape, but if you stay one or two threads you should be safe enough to use tape. It is your choice..
   / Tape on hydraulic connections? #3
Thanks
I don't know the particular fittings you will be using, but GENERALLY they are flared to match each other and the threads merely pull those surfaces together - i.e. the threads themselves are NOT where the seal is made.
About the only "purpose" it serves is to lubricate the threads, so you will get a little more clamping force for any given amount of tightening torque.
There may be SOME corrosion protection, though I doubt that it is meaningful.
I have used tape, I have never had it result in a problem, but I have given up using it.
You may be better and more careful than I am, but there is always a CHANCE that someone else will take it apart at some point and little bits of tape debris will get into the hydraulic system.
SUMMARY: You don't need it, it doesn't "seal", there COULD be problems with it later on.
   / Tape on hydraulic connections? #5
+1
Leave a couple threads at the male end free of tape. Looking at the free end of the male fitting, wind the tape around it clockwise.
Sean
   / Tape on hydraulic connections? #6
Lots of threads on this, and equally lots of debate. If you search the term "PTFE" you can read for hours.
I am in the "no tape" camp, prefer a quality PTFE paste that's rated for hydraulic use. But-depending on what fittings you have you may need nothing, NPT threads are the only ones that need a sealant.
Thanks for all the advice. I just put the hoses on the cylinder. Decided to not use tape. Of course if it leaks then I might have to reconsider. Now only 20 more days until I pick up the new baby!
   / Tape on hydraulic connections? #8
I have mostly used tape (male npt), but lately have switched to only paste. Less possible problem, I guess, with paste and a neater look too.
   / Tape on hydraulic connections? #9
You need to consider the fact that NPT is designed to compress the threads together, and relies on something to fill the small voids. You normally always use something on NPT threads. Also, NPT was not designed to install and remove over and over. One or two times compressing the threads is about the limit.
   / Tape on hydraulic connections? #10
Just by using a thread sealant you actually protect the tapered threads by providing both a lubricant and sealing agent in one. You may get twice the number of re-uses or more.
Sean
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
MONITOR WITH BUILT IN COMPUTER (A53843)
MONITOR WITH BUILT...
2010 KMC 3376 Peanut Combine (A53473)
2010 KMC 3376...
