Bucket not level on new MF GC2600
   / Bucket not level on new MF GC2600 #11
The pressures are the same but are the tires the same height? Does one look to have a larger bulge in the center? May be worth a quick circumfrance measurement to check out.
   / Bucket not level on new MF GC2600 #12
OK, guess I'll have to do this the right way...
1. Use a jack to ensure that the frame is level (same height from level concrete floor, on BOTH sides).
2. Measure height from floor at:
a)FEL lip
b)FEL lift arms
c)FEL pin cradle
d) any other points that appear significant.
I did some preliminary measurements, and found that --preliminarily, mind you-- that the bucket lift arms and pin cradles are 5/16" lower on the right; also found the frame was 1/8" lower on the right (most likely tires).
That still leaves a difference of 3/16" (lower) on the right.... but I'll check that more thoroughly later. Now that I've begun this, the carb on the rear cylinder of the Virago will have to wait,:( and I'll dig into this "FEL not level" thing.
Gary, I realize it may look like the crossbar is level with the FEL, but I'm convinced there's a discrepancy somewhere. I'll try to check it out more..uh.. scientifically.... like an engineer should... later.
Thanks to all for the interest; it really is a bit of a pain to have the FEL always digging in deeper on the right side. I'll get to the bottom of it sooner or later.
Thanks everyone for the information. I haven't had a chance to get to the manual yet. There doesn't seem to be much that can be adjusted. I will update after getting a chance to look at it tomorrow.
OK, read the manual and there is nothing, I am going to double check the wheels. the left side still look "over inflated" compare to the other side. It's the difference between the left and right is 1/2". I can live with this, but really don't want to.
   / Bucket not level on new MF GC2600 #15
How old is the tractor? if it's new, don't mess with it, the dealer should fix it. If they balk, raise a fuss if it's still under warrantee.
   / Bucket not level on new MF GC2600 #16
Post pictures if you can.
But be sure that the pad you are measuring from is completely level.
It doesn't take much to alter the looks of things.
EDIT: IrvingJ, be sure to check your concrete pad also...........I see a crack in the concrete in front of your tractor.............concrete will shift, thus making things look funny.
The concrete I have here is all crooked, it was laid "HOT".............wasn't time to make it perfect.
   / Bucket not level on new MF GC2600 #17
Very observant, Don! Yep, I made that crack.:mad: Should have put a piece of PVC pipe in for future electric feed, but didn't... and of course, when I went to drill a hole after the fact I hit a piece of rebar darned near dead center. I also had some drainage issues --which caused frost issues-- that weren't taken care of adequately before the slab was poured. One of those learning experiences.:ashamed:
The tractor parks behind the cracked area, but I'll bring it inside where I have a good chance of finding concrete that's reasonably level; perhaps not exact, but real close. I figure colse enough to notice any discrepancies in the frame.
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
2019 Fontaine...
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
