Hello,
I have been tracking down an issue with the 3pt on a Ford 1500 that I recently purchased. The threads here have been incredibly helpful (many thanks to JC for his well documented 3pt overhaul.) Initial issue was that 3pt was down and unresponsive. That turned out to be a control valve that some previous owner had broken thru overheating the relief (which was stuck open.) At that point, the 3pt reacted beautifully to compressed air blown in the inlet to the control valve. When I connected the pump discharge line to the control valve inlet...nothing. At this point, I figured there was a problem on the pump side.
On the pump side, there was the typical VERY clogged inlet strainer. When I gave this guy a good bath in a parts washer. The pump came alive and would make plenty of flow with the discharge disconnected. I then connect the discharge and the 3pt reacts to requested position, but very slowly. It lifts, but only if there is no implement and no me standing on it (~2000 rpm.) Once it gets to position, it does hold position well, so I figure the cylinder seal and check valve are in fair to good shape. I take apart the relief valve and all looks well.
So, I tear into the pump. Sealing surfaces between gears and aluminum housing (both sidewall and outer cylindrical surface) of the pump look good (no detectable ridges or scoring with fingernail.) Seals all "look" good.
Finally, HERE IS MY QUESTION. There is play between the sealing surfaces of the gears. The gears still fit nicely on their shafts, but the driving gear can be turn a few degrees, clockwise and counterclockwise, before engaging and turning the driven gear. Is there still hope for this hydraulic pump, or am I out a whopping $1500 for a new one (it hurts to write that)?
Thanks for the advice.
