Buying Advice Are rear remotes standard on the DK40 and DK45?
   / Are rear remotes standard on the DK40 and DK45? #1
jkski
Member
Shopping
I have looked at these tractors and the Bobcat tractors so much now that I am starting to forget what is standard and what is not. So, refresh my memory, are a set of rear remotes standard on the DK40 and DK45? How about the Bobcat CT440 and CT445?
Thanks,
   / Are rear remotes standard on the DK40 and DK45? #2
Rear remotes are standard on the kioti but are an add on for the bobcats.
Thanks for the quick response. Are the rear remotes standard on both the DK40 and DK45 or is it just the DK45?
Thanks.
   / Are rear remotes standard on the DK40 and DK45? #4
All Kioti DK SE series have 1 set of rear remotes as a standard item.
   / Are rear remotes standard on the DK40 and DK45? #6
Thanks.
my 2nd rear remote added $400 if i remember right. its a must have item by the way.
the first (included) set has the detent. the second does not. I'm glad that the second doesn't. The detent is great for log splitter, horrible for everything else.
   / Are rear remotes standard on the DK40 and DK45? #7
Is a 2nd remote a dealer installed item?
   / Are rear remotes standard on the DK40 and DK45? #8
usually. i had my dealer do it. im not sure if its easy to do yourself or not. I personally wouldnt know where to buy the things from
   / Are rear remotes standard on the DK40 and DK45? #9
I bought the rear remote (Kioti factory) kits from Wallace tractor, when he sold Kiotis before being a Bobcat dealer, and installed both of them myself on my CK30hst. It took me about five hours but I think I could do it faster now. They came with instructions and the install is straight foward and you don't need to be a master mechanic to accomplish this if you wanted to try it yourself.
You can also take out the detent balls from the remotes if you don't want them to hold in the detent position.
   / Are rear remotes standard on the DK40 and DK45? #10
ya, i thought about removing them, cause they are a pain in the butt, but i do need them for my log splitter.
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2012 Ford Fusion SE Sedan (A50324)
2012 Ford Fusion...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
