I broke my carb on j/d 214
   / I broke my carb on j/d 214 #1
wenailem1
:confused2:
Hello everyone, i'm in some trouble, long story short, leaky carb,change gasket, easy fix, no, bowl bolt strippped tapped it broke the cast inside here main needle goes, locate new carb 3 wks later, not a kohler, but a walbro,install it,fires up, it has 3 adjusters on it, cant seem to dial it in, its a k321aqs motor, the new carb is off a newer motor with identical #'s however the # inside the carbs are different, the old is 30 m and the new is 60 m. im also concerned about running lean and blowing up my motor. one last ? there is a aluminum gasket between the valve cover and the head, are they reusable, or can i make a gasket and add to the aluminum one. turned out to be a long story. thanks guys
any input?
   / I broke my carb on j/d 214 #3
Sounds like a question you should post on Weekend Freedom MAchines. everyone on there drives old tractors. I have a 214, but have no insight for you. Good luck!
Thanks, I'll check that out.:thumbsup:
Wolverine Quick Attach Tree Spade (A50514)
Wolverine Quick...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
UNUSED FUTURE MINI EXCAVATOR AUGER SET (A51244)
UNUSED FUTURE MINI...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
