Wider Rear tires on a 755 ?
   / Wider Rear tires on a 755 ? #21
My tractor is a 1992 model. I purchased it and the deck new at the same time. I don't see any differences on JD Parts as to s/n on the deck frame, but they made that deck a long time and I would guess there were differences over the years that were considered not worthy of a s/n break.
   / Wider Rear tires on a 755 ? #22
I purchased mine (with the deck) new in March of 1990, so the model year is likely an '89 or '90. I just checked the manual for the deck, and it indicates that the front draft arms are adjusted to set the deck level front-to-rear.
   / Wider Rear tires on a 755 ? #23
The 755 tractor s/n range for 1989 is 595001 - 750000. The range for 1990 is 010001 - 100000.
2017 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2018 FREIGHTLINER M2 106 26' REEFER BOX TRUCK (A54607)
2018 FREIGHTLINER...
flooring (A53424)
flooring (A53424)
UNUSED LANDHONOR RTH-13-2000G HYD TREE GRAPPLE (A54757)
UNUSED LANDHONOR...
Ox Bodies 13.5ft 12-14Yd Dump Box Truck Body (A52377)
Ox Bodies 13.5ft...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
