2520..So I installed a Temp Gauge
   / 2520..So I installed a Temp Gauge #1
PCABE5
Wisconsin
John Deere 4066R Cab and loader
I was looking for something to do this weekend so I installed a temp gauge. Everything was really easy to hook up. My only mistake was I scratched the black plastic right below the gauge but I am sure the tractor will survive. Easier to read then the light and easier to tell when the front grille is getting clogged. The gauge reads 160 when it warms up which is when the T-stat opens.
   / 2520..So I installed a Temp Gauge #6
Nice!:thumbsup: I have been wandering about that and if they have an idiot light on them to let you know if it is getting hot.....
   / 2520..So I installed a Temp Gauge #7
There is a plug already there. Just remove it.
If you have a block heater (like me),that is already being used. Not sure,but I don't think there is anywhere else to put it.:(
Greg
   / 2520..So I installed a Temp Gauge #8
Greg
On my Kubota (B7100) I couldn't find a tapped hole for a temperature sensor, so I used some copper pipe fittings to make a short insert into the top radiator hose. I soldered a brass fitting into that copper section for the sensor.
Works great.
   / 2520..So I installed a Temp Gauge #9
Greg
block heater should be in the block on a 2520, not the thermostat housing...
look again...
   / 2520..So I installed a Temp Gauge #10
Greg
The block heater on my 2520 is installed in the side of the block. The fore mentioned plug is still there and is not big enough for a block heater.
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2021 Deere 331G (A53317)
2021 Deere 331G...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
