Jinma 284 electrical schematic (2005, integrated instrunment panel)
   / Jinma 284 electrical schematic (2005, integrated instrunment panel) #11
Well thru the key is how it came from the factory, and it has been working without issue for 6 years now...
Yes, but the real question is "has it been working well?". The Y85 series engines are notoriously hard starters when cold. That's well documented. Out of sheer principle I added both a starter relay and a glow plug relay. Colds starting aggravation became a thing of the past - and extend the life of the OE keyswitch considerably.
//greg//
   / Jinma 284 electrical schematic (2005, integrated instrunment panel) #12
I bet those matching belt and suspender outfits are hard to find:D:D:D:D --just joshin
//greg//
Mine has always started fine in the winter, even with the bad connection I found in the glow plug circuit during this evolution. In fact, I am still running the original chinese battery:) I did add a 1KW tank type engine pre-heater last year to make the real cold starts a little less hard on the machine... Not that it gets especially cold here...
All good food for thought!
   / Jinma 284 electrical schematic (2005, integrated instrunment panel) #14
In troubleshooting my tach failure (bad sensor, only putting out .5V signal instead of the nearly 5V signal the tach needs to operate) I pulled my cowling and also did some wire cleanup. This gave me the chance to finally finish the updated electrical schematic I started several years ago, which I have attached here.
Enjoy!
Ron,
Nice work. It will help out a lot of owners...Mike
   / Jinma 284 electrical schematic (2005, integrated instrunment panel) #15
Hi greg I am new to tractor stuff, could you or will put a diagram of how to do the thing you did. I am not a electrician or a mechanic. It sounds like a good idea but I am visual person so diagram would help a lot. It seems to me the wire from start switch should go to s terminal. What am I missing?
   / Jinma 284 electrical schematic (2005, integrated instrunment panel) #16
Nice, Ron
   / Jinma 284 electrical schematic (2005, integrated instrunment panel) #17
has anyone seen a wire color chart for Chinese tractors??
With so many variants, I would be surprised if wiring colors were consistent. I think that is why they number them...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2020 FREIGHTLINER M2 26FT STAKE BODY (A59575)
2020 FREIGHTLINER...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2022 John Deere 1025R (A53317)
2022 John Deere...
Sedan (A59231)
Sedan (A59231)
American G-Model Pump Jack (A56438)
American G-Model...
