A question about washing my tractor??
   / A question about washing my tractor?? #1
Gobblin Tom
Gold Member
Western, PA
2011 JD 2520
I have been doing a lot of work in the woods with my new JD 2520, I have been trying to get my paths straightened out but have run into 5-6 springs along the way so things have been interesting to say the least!! Anyway I was just curious if it would hurt the tractor to use the power washer? I don't know if there is any areas that I should be careful as in electronics, etc. I really want to get the under carriage cleaned before putting the mower deck back on. Oh yeah this is one situation that I wished I had the back hoe....:(
   / A question about washing my tractor?? #2
No problem I have a 4000PSI washer not a mark on my tractors.
   / A question about washing my tractor?? #3
This is where you want to have one of the low pressure ones. I have seen real high pressure washers peel paint. I would not hold it too close.
   / A question about washing my tractor?? #4
Ha! There you go. We both answered at the same time with conflicting answers. Go figure. :)
Yeah I know you can't hold it to close..... was more worried about seals and electronics.....
   / A question about washing my tractor?? #6
you just may want to be careful around any stickers/labels.
   / A question about washing my tractor?? #7
I would just use a hose with a fairly good nozzle. A pressure washer is over kill and risky for just washing the crud off of a tractor.
   / A question about washing my tractor?? #8
A ham fisted operator can break anything....
Use a 4000 PSI washer at 1" with a 0-degree tip and you'll do damage. A 2000 psi unit at 3' with a 45 degree tip probably has less cleaning power than a garden hose.
Pressure washing is fine, if you are smart about how and where you direct the streams.
Start with a wider spray and work at a distance, if you are not getting the cleaning you need, get closer and/or narrow the pattern.
   / A question about washing my tractor?? #9
Pressure washer works great, to remove that really thick mud, just don't blow the stickers off of it, or soak the alternator or anything like that, I go easy on the dash panel also, but other wise just wash away.. Mine is 2700 lbs.. just use common sense.
James K0UA
I have a lot of clay stuck on it and I just have a spring for my hose so I don't have a lot of pressure (Has a pump though). I don't think the hose will come close to removing the clay....????
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2017 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
