MF 12 sticking bales together, Help!
   / MF 12 sticking bales together, Help! #1
Birch Hill Farm
Kentucky
International 444
Hello, I have a a MF 12 bailer which we ran about 400 bales through over the last 2 days. The longer we baled the more it began to have bales stuck together. Its always on the in board side and it would be about a 3" diameter tuft of hay still connected to the previous bale. It really became a pain having to jerk and yank to separate the bales. What should I look for to remedy this? Other than this issue the bailer has worked perfect.
Thanks-jon.
   / MF 12 sticking bales together, Help! #2
Sharpen the plunger and bale case knife and reregister them (they are probably too far apart to cleanly cut each flake).
Thanks. I did notice there is a gap between the blades as they pass each other. How much of a gap if any should there be and how do I adjust it?
Thanks! Jon.
Just to close out this thread, there are 6 bolts down the out board side of the chute that thread in and push the plunger unit over. By tightening it moves the plunger blade over reducing clearance between it and the stationary blade. On mine the last two bolts had broken loose from where the nut was welded to the side of the chute. The result was the chute moving over and allowing about 1/2" between the blades. Any way maybe this will help a future search.
   / MF 12 sticking bales together, Help! #5
I don't have a baler --probably never will:laughing::laughing:-- but thanks very much for the clear follow-up & diagnosis. That's how we all learn!:thumbsup:
I trust your baler is now working well.
   / MF 12 sticking bales together, Help! #6
Thanks! Jon.
1/16" or so on my MF124 baler. Adjusted by thin metal shims between the knives and the plunger and the bale case.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
2014 XL SPECIALIZED TRAILER XL 110 HDG RGN (A52472)
2014 XL...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
