New tractor owner
   / New tractor owner #1
GregbkH
Gold Member
Wisconsin
2010 New Holland 3045
Today I became a new tractor owner. I have been studying tractors for over a year. I stumbled across this site last year and thanks to the knowledgeable people here, I finally decided on a 2010 New Holland 3045. It has the TL250 loader and the 758C back hoe. I'm having 3 rear remotes installed and all 4 tires loaded with Rim Guard. I also ordered the Land Pride RBT3584 rear blade with all the hydraulics for my first implement.
Sorry no pics until delivery (hopefully next weekend).
Thanks for your help
Greg
   / New tractor owner #2
WOW! Get it on GregbkH and welcome to TBN! Pray tell, what are you planning on using the third set of rear remotes for? Keep us in touch as you go along and remember-photos are required!:thumbsup:
   / New tractor owner #3
Greg
Cool:) and welcome to TBN Blue,
All on the spot choices. Please post pics asap so the drooling may start.
Good luck and take it nice and slow till your tractor breaks in well.
JC,
   / New tractor owner
I wanted to make sure that I had enough!! I plan on getting a TnT and want to be able to run what ever hyd component an implement may have.
   / New tractor owner #5
Welcome. What is your first project and do you have any pics of this fine collection of machines?
   / New tractor owner #6
I have two sets of remotes and a Woods block for the backhoe all in one stack so adding a third set of remotes wouldn't be feasible do to so much already going on there. I checked the stud lengths for the third set and they are too short to connect them all. What I do is detach the tilt cylinder when I run the wood splitter.
   / New tractor owner
Thanks for the comments.
I guess my first project will be to dig out a few stumps in order to make it easier to navigate my trails in the woods.
Here are a few pics as it sat on the lot.
   / New tractor owner #8
Nice looking machine. Have you thought about putting a thumb on the BH? I have a Kubota L35 and wish I had done that. I'm looking at getting one from Bro-Tech, but man are they expensive.
   / New tractor owner #9
Welcome aboard nice piece of equipment you got there :). There is a lot of good advice on these forms if a problem should occur which I highly doubt that's one tough tractor. The thumb on the backhoe might not be a bad idea to help with stumps and other debris if one is available for that model take care
   / New tractor owner
A back hoe thumb is definately on my list. There are so many attachements that I want/need!!! I have to take it easy for a while or the significant other may take notice of my addiction! :thumbsup:
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
